electrical issue
jabrow87
33
Nov 26, 2008
River Falls, Wisconsin
so i just installed a gm iat and map sensor, i also was moving around and cleaning up some other wiring. so now i hook up dsmlink and it shows -74 for coolant and intake temp, like 200 counts of knock and its not running, tps is 100% all the time.. anyways it turns over and kinda starts but i have 0 ecu grounds and i was wondering where the main ground point for the ecu is
Did the car start and log all the parameters just fine before you wired in the IAT and MAP sensor? What did you use/follow to wire in your IAT and MAP sensors? I ask because I've done a write-up on each just for logging in dsmlink, I'd start over and follow them as I'm sure you cut the wrong wires if everything else was fine before the install.
-Wiring & logging a GM IAT sensor
-Wiring & logging an AEM 3.5 bar MAP sensor
Your ECU's main ground is Pin 13 & 26 and Pin 92 is the ECU's sensor ground, look at this pinout if you have to. 2g ECU pinout
:dsm:
