new stuff
baxsom
480
5
Jul 10, 2004
san antonoio, Texas
so here are the results from the weekend of injector fighting
many thanks to everyone that gave me advice on how to get these things in
i had my stock throttle body ported and polished out to a full 52mm
and put in 270cc injectors
still withing the stock ECU's ability to control
it feels more responsive
right off the bat
it took about 30 minutes of driving before the ecu settled down the idle and after that
i could feel a difference
granted since my palm is broken i cant log real numbers to make sure my car is actually doing what my butt says it is
however the crappy air/fuel gauge is going to full rich at 10psi
something it never did in the past
now i just need to get it to the dyno
Get to a dyno and make sure you tune it well. Do you have an safc or some other way to tune?
no afc
because the stock ecu is more than capable of running 270cc injectors without help
also the techs at hahn say that an afc such as the apexi was never meant to be ran on a 2gnt so getting them to work is a hack job
i trust their judgment and opinion so i am waiting to go any bigger on injectors until i can get a portfueler
what a dyno with an air fuel meter in the exhaust can do for me is tell me when i hit my limit of boost
  • For sale 1g 1991 Eclipse GSX
    1991 Eclipse GSX $7,800 100,500 miles Clean Pa Title In Hand NO Trades Manual Transmission...
  • For sale 2.3 Stroker Galant VR4 Roller
    2.3 stroker block, forged rods and pistons. Needs to be gone thru (ballhone, rings and bearings...
    • brane_97talon
  • For sale New OEM style 2g Headlights
    New 2g OEM style headlights. Bought for my Spyder turbo conversion. Car long gone.125 shipped...
    • brane_97talon
  • For sale Hafe Stainless Exhause Manifold with External wastegate and welded 7cm housing
    As pictured, HAFE stainless exhaust manifold with welded 7cm housing. Bolt on TD05H setup. These...
    • brane_97talon
  • For sale JDM Valve Cover
    As pictured, JDM Valve Cover. Good condition. Bought about 10 years ago, possibly from the same...
    • brane_97talon
