mach4g63t
- 402
- 1
- May 28, 2007
St. Louis,
Missouri
Here's the background (mods in profile) . . .
I just put a new head on my car when my other one crapped out. Got new ARP's and a Cometic gasket sealing it all together. Compression tested the engine and it's running 130's across the board (not really happy about that). Everything is torqued right and triple checked. My buddy, who is very experienced with DSM's help me do my timing, and everything is back on as it should be.
Now, when I start my car it turns and I get a few sputters like the cylinders are trying to fire but then it's as if the starter encounters some hesitation and something is keeping it form turning the motor over.
Sort of like this (excuse my improvisions on sound)
Dun-dun-dun-skip-dun-dun-skip-dun-dun-dun-skip.
It has plenty of juice, as I've drained almost two batteries of life now. The weirdest thing also is if I take out the plugs then try to crank the motor is just turns over fine without the skipping in the start.
I just don't understand what it's doing. Is my timing off? I don't know what's wrong and I can't figure out why the car won't start.
You first have to get the car running before you set the base timing, but you definitely have to do that after removing and re-installing the head. But first you have to get it running.
