2G Need help with cams!
Covoss
58
5
Apr 18, 2024
Martinsville, Indiana
I need to know if the evo 9 cams will fit a 4g63t 7 bolt, I'm in desperate need of them and found a good deal. What all modifications would need to be done to use it?
Short answer is no.
Not quite as short but slightly more helpful answer: The Evo 9 has MIVEC, you'd have to extensively modify the head and valvetrain to actually make any kind of use of the MIVEC(Kiggly Racing has a write up on these forums with all he had to do to use MIVEC on his DSM) and at that point it's literally just a stock cam. You're better off researching on the best aftermarket cams for your setup and going that route.
