Need help with swap
combatmedic
217
Jan 27, 2010
Fountain, Colorado
I have a few more questions with this swap if you can help me out with. I am going by this "how to" How to do a 6 bolt swap and what you need
I just have a few questions:
1. Im a little confused with step 4 when he talks about the AC
2. Does the 2g intake manifold bolt up to the 1g head because number 5 confuses me
3. I am confused with 14 and 15.
Thanks for your help I really want to get this project done.
Could you reference the "How To" you are using? First off the 2g manifold will not fit on a 1g head. The intake ports on the head are too large and the 2g intake manifold will not cover them up.
Ok found it.
1. He just means you can use a 1g A/C compressor if you change the harness. If I were you, I would just use the 2g mount and compressor so it connects right up.
2. The intake ports on the head are too large and the 2g intake manifold will not cover them up.
3. You need to trim the starter plate that goes between the transmission and block.
