InfiniteGSX
- 3,182
- 16
- Dec 10, 2002
Tijeras,
New Mexico
I got a "Built" 6bolt motor with 5000 miles on it from a friend. A very respectable guy. I don't know how long its been without oil and I've had it for a couple months already. It just started an hour ago. Its limping right now because not everything is together yet. I just needed to confirm that it would run before putting everything else back together. Its on a NT Eprom ECU (my ecu is at my girls house
), No MAF, and 1 bolt holding the O2 housing on, and its still loose so the o2 housing moves around. I put oil directly into the fill tube... I should have just pulled the valve cover and poured the oil on everything.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/QJwsXcY9ZYs&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/QJwsXcY9ZYs&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
I think it sounds like loud Lifters/Valves. Maybe because the motor hasn't had oil in forever and the lifters are stuck?
I know the knocking is loud, but it just doesn't sound like rod knock of any sort. I've heard a lot of rod knock in my day... and it seriously just sounds like really loud lifters. Plus Rod knock isn't a consistent knock, And this is a consistent knocking sound.
What do you think?
), No MAF, and 1 bolt holding the O2 housing on, and its still loose so the o2 housing moves around. I put oil directly into the fill tube... I should have just pulled the valve cover and poured the oil on everything.<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/QJwsXcY9ZYs&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/QJwsXcY9ZYs&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
What do you think?
