My Thoughts and experiences building my own trans
turboglenn
6,375
124
Nov 5, 2007
RIpley, West Virginia
Well, after getting my trans i built intothe car, filling the fluids, puttig everything else back in and checking operation, I was plased to notice that all gear were accesible wioth the engine running (although alittle notchy - but no morethan the new TRE FWD unit i bought in 2009)
I shimmed the input with .006 preload, the intermediate with .0075 preload and the center diff with .0075 preload. This made the input shaft almost impossible to turn by hand while off the car andin gear, but i was told this is normal with performance shimming by tuners member donniekak.
ONCE i was ready to test drve the car I took it around the block maybe 3/4 of a mile and noticed some grinding on the 1-2 and 2-3 shifts (but very light grinding) I wasn'texpecting perfect because i used all used gears and synchros becayse i needed the money for bearings, clips, roll pins and a nwe center diff (didn't want torun welded on my DD)
** Now, knowing my TRE shifted WAY better at higher RPM's than it did at lower ones mostly when new but through it's entire life really, so i decided to rev the gears out in this trans and see what happened. Much to my surprise any shifting over 4500-5k RPM was flawless, easily engaged and no grinding. I continued to put another 17-20 miles on the trans and with each low RPM shift (while waiting on the syncrhro and not forcing it) the shifts got better and better..with each couple of miles and shifts there was notable improvements, and i think part of this may be because although i lubed poarts while asembling, i probably didn't getthe shift rails and internal gear cluster parts lubed well enough and the driving helped get them oiled te morei drove.
note on the bad shifting: I found that the shift levers at the trans (or at least teh one that bolts on stansd up and down) was bent and causing a very stiff shifter feel, luckily I had my old one and swapped it on for an immediate cure
after blowing the last trans in third on a smooth pull (but one of many back-to-back dyno pulls) i decided to turn the boost down, not go WOT fully and use only about 3/4's the rev range ihave, everything was flawless, this trans has NONE of the noises the old one did meaning that oldone must have had some of the mostworn out bearins i've ever seen in a trans LOL
During the build i picked allthe least worn gear/synchro combosfor each of them 1 through 5 and used the huibs andsliders with the least wear also.,the shift forks are brand new (cheap assurance of good shifts) and everything was done exactly accordingtothe book except forthe shimming spes and anothr thing Tim told me to do with position ofthe 1-2 slider.
Although the shimming is supposed to help the trans hold power i'm stillafraid toget the boost up and go for it, but i'msure i'll worl my way up there once i find extra transpaarts (all i need is a good intermediate shaft to buld a back-up transa at this point - anyone got one???)
Overall the job was easy, shimming beingthe most tedious because of the mistakes I made is solder choice for length of pieces used, but once that was established the only thing i had to really spend timeon was making the shims i didn't have by either cutting down larger diameter ones in the right thickness and putting themin smaller race holes, or by using some machinist shim stock and cutting a "backing shim" to go behind the ones i already had.
the time spent and the pain of workin on the car was the worst of it but without money to pay another person to do it ihad little choice, but now i'm confident in my tranny building skills :D
MY back up I hope tbuild with hopefully the Evo III 1st, 3rd ad 4th (or at leastthe 91-92 3rd 4th, hub and slider_ to make them tougher, I'll also take the time to debur and detail all the gears as well, and order them shot peened as well if money is there for this)
I would say the two things that made this job the easiest with removing and isntalling the trans was a 3/8th's air ratchet and an engine hoist which took at least an hour off the install and the AR taking another 45minutes off my normal time too)
One thing i did learn and will add to my tips thread is that minor blemishes are EASY to miss, I wuld have almost put in a bad 4th gear had i not taken the time to look over every tooth afterfinding some chips in another trans i was salvaging parts from. Another tool that greatly helps is the input shaft holder, I made mine from cutting the center out of a burnt OEM disk and welding it to a 1" socket. Wihtout this i would have been on the "penny trick" to get the 105 lb/ft end nut toque and i don't trust wedging anything between gears i want to last any amount of time
A press and bearing splitter/gear puller are two "must haves" to do it right (can get by wihtout spltter tim says) but i wouldn't gop wihtout at LEAST the OTC1123 model as i tried with the harbor freight units and had more trouble than success., and you don't need a 12-20ton press if you have welding equipment and some metal, I lengthened my 6 ton mini A-frame press from HF to be just long enough to dothre trans work and now i'd rather have it for thsi job than a huuge floor model because i can put it on my welding table, sit down and calmly do my work without straining my back or leg
I would say the HARDEST part of the entire job was lifting the t-CASE with driveshaft in it up into place during the re-assembly, that thing is like bench pressing with an arm tied t your head LOL
Overall, to sum it all up, I'd say if you're mechanically inclined enough to not have to ask how to take it apart, or know how to buildan engine, change CV's or aout anything that a decent mecanic can do, then building a trans is within your realm as well. I'd say the most important part is paying maticulous attention to detail, and make sure there's no chipped teeth, that the synchro keys aren't worn but also that they don't pop off the springs when you're placing the slider over them (holding both synchros into the hub makes this easier) and aside from that justbe able to recognize if your solder checks just seem "out of the ordinary" when using new bearings especially
Tim Zimmer says he sees values in the .040 +/-.005 or so on both input and intermediate and closer to .050" on the center diff (there's a thread called "Gearbox shimming expert needed" where Tim lays out a good bit of info.
search for it, it's a good read!
I have a few tips for your next build. Don't put the slider over the hub with the keys in. Put the slider and hub on the bench then just drop the key s in and put the spring in. Flip it over and do the other side. Mind the possible issues with non symmetric hubs/keys etc per the manual.
20 ton press isn't necessary but it's WAY nice as it's so big you don't have to hassle with trying to make things fit.
There are OEM part numbers for hub/sleeves that include the synchros. Read through the TSBs and ask questions of the dealer. A better dealer will let you order the part number and see what it includes. Some 1/2 hub/sleeve kits also incude hubs but both 90 and 91 up intermediates. I"ve assembled a hodge podge of numerous different years with good results. 90 trans with 90 center diff but larger intermediate and double 1/2. Gvr4 1rst input, 93 up 3/4, 92 3/4. You name it if you're willing to learn which parts interchange.
If you had trouble putting the tcase up you didn't have the car high enough in the air. I can put mine flat on my chest and lift it up easily.
I've lost count how many transmissions I've built. It isn't bad, just tedious as you stated.
I think I freaked a guy out when I had his unit on the bench and gave it back to him in boxes in 15 min. Air tools rule.
Thanks for the tips, I'm definitely hooked on learning about trannies, even got over my dusgust of gear oil smell :)
As for the T-case, I have a reall weak back and pretty much a useless left leg and hip from a motorcycloe wreck so all i was able to use were my hands and for-arms to put it in, and the weight of that and the shaft were really doin a number on me
I'd like to find a spare intermediate shaft, a set of HD3/4 gears with hub/slider and fork/rail to make them work. The evo III 1st would be nice but isnm'tneeded, I just want to know i can do third gear pulls and not shatter parts out of no where at ~450lb/ft torque, then adda a 4spider center diff andabd possibly a twin disk,i9 want a clutch that i can get hot leaving the line and won' slip opnce i hit 3nd and 3rd
I'd als like to rig up a tranny vooler,icouldn'tget an answer hen building this one but i have some 8AN fittings i could have put in the cases, and i also have some hydraulic fluid pumps from a set of small hydros i doubt i'll ever use at this point
Congrats man, I know this wasn't easy, can't wait to see you rollin around sometime. Just might want to keep the boost a little bit lower so 3rd doesn't go through the transmission this time :D
That's good stuff to know... I'll be tearing mine down before long too. I believe the gears are fine, but I know my 1-2 synchro is beat to death. I would love to get a double synchro set and press that on instead, but they aren't exactly the most affordable things you can get for a good transmission build. What I would like to know is if the "taller Evo 5th" upgrade I see mentioned on sites like Jack's Transmissions is worth the money. I drive a lot of highway miles and I would really like to raise the 5th gear ratio substantially, just to drop the rpm at cruise and save me some gas. I have also wondered is anyone makes a wider gear set. 1st is just plain too short in my opinion.
IMO the longer fifth is nice, it makes that just slight difference that really counts.
I don't drive my DSM a lot on the highway but from the standard fifth gear driving i do, it has definitely made a difference in the MPGs, even with my not finished tune.
They make a couple of taller 1st gears. They make the evo3 which is the one everybody uses being its the strongest of the bunch. Its a 2.75. They also have the galant gvr4 first gear. I believe its a 2.84. Its not as strong as the evo3 and has been known to break. Its still good for a fair amount. The last would be the jdm galant rs first gear. I believe its a 2.57. If im not mistaken this one has to be used with the jdm galant rs second gear also. Which is slightly taller than the udsm second gear. This first is also considered weak.
Well there's a fewthings to point out.. if you've got a 2g car, then you ALREADY have a double synchro 2nd gear (the rest all have one synchro)
AS for a taller 1st gear putting the EVOIII input shaft in the trans will allow you a much taller first gear, bringing the top speed of first up to like 45MPH @ 8k RPM instead of the 33 or so we see now.
The fifth is kinda cool but if you've got a big turbo it can be real annoying constantly downshifting to fourth on the highway because you're at 2600 RPM doing 65 and need to go up a hill
The EVOIII 3rd and 4rth are actaully "shorter" making the gap from 2nd to third and third to 4th less notable and keeping you in the meat of the engines power easier.
overall I'd like to have the EVOIII 1st gear, stock 2nd and EVOIII 3rd and 4th with a stock or maybe slightlyb taller 5th, but my buddy has a 67mm turbo and the tallest fith he could get and it sucks on the highway, he hardly uses it unless he'dgoing over 80mph
Steve, about third gear, I'm only on 24psi at best right now and i'm not even using third yet LOL, but with the tighter shimming i thnhk i'll be OK, you could hear the cluster bearings in the olld trans rattle and howl anytimethe car was rolling slow enough to hear things other than the exhaust. Even revving in neutral the trans made horrible growling noises that are all now gone, and ithink with the shimming set to the bottom end of the "under 600tq) and over the "400tq" settings that TMZ uses i should be able to makeitlast a little longer a note on gas useage the 4g63 is more efficient at 3k RPM than it is at 2500 RPM, it has to do with the engines design, VE, etc.. I can only prove this from all the engine tuning i've done that shows me needing less pulse width in the cruise areas at 3k than i need to maintane the same AFR's at 2200-2600RPM so being at 3 is good, beiong over or under eats more gas
doing some reading i learned that probably a good part of it was doing so many back to back pulls, I probably did 12 pulls in a row that night, the FMIC wasn't soaking at all really with a good fan on it and the coolant temps were steady at 185'ish so i just kept on going, but nnow i've read alot about heating up and repeatedly stressing the gears and that you should let them rest and cool between high power pulls.. now i know (and knowing is half the battle LOL)
The Galant VR4 has a taller first gear but it is also weaker. Jacks Transmission has a good write up on in it!
Jacks Transmissions LLC — GVR4 1st Gear = Weak
Ill have to come and have you hear the sqeaky clutch engagement I have...God it's annoying mainly engine breaking, but probs not as bad as bearings all over the place.
as for 3k RPMs being the efficiency point, you can almost "Feel" the difference in shifting from 1st to 2nd at that rpm vs. 2500.
Unlike most engines that are about 2500 perfect shift point (MPGs in mind)
I've heard that adding a manual tranny cooler can almost double the life of a stock trans at higher power levels.
When I have spare time and money, I'm going to set up a scavenge pump and have it run the oil through a cooler and spray it over the 3rd gear hub/gears.
2g 1st-2nd is already a double synchro? I need to look closer at this FSM...Yup... well, that takes care of that. :D Mine is probably just really chewed up.
If the engine is most efficient at 3k, then that's about where it sits when I'm at cruise on the highway, but that's at 70ish. Really, I think it'd be nice if 3k at cruise was around 80mph now. I'm one of the few people that does 70 on our highway going to work because the cops see my car and get a woody to write tickets. If i were to keep up with traffic, I'd be doing 80. Learn something new everyday... Thanks Glenn! I also appreciate the input on the gear options guys. That's a few options I also didn't know of. Thanks.
Ya know i've been watin to do the same, i've got sm -8 fittings (need line unless some -6 wouls suffice) and i have a hydraulic pump from a chrylser sebring convertable top (wanted to use the cylidenrs and stuff for something cool but never have) So i was thinking about making my own cooler, but want to talk with some one that has more experience in them before i do.. want to know the best place to pull and return fluis as well as the best type of core to use.. Imade my own oil coolers and some for others by gettiung dodge truck cores from the bone yard and welding -6 lines on them and putting them in the area on the driversside where the scoops are made like feeds the stock SMIC
any info you have would be great
H@tGSX only 2nd is double synchro, i see no need for first unles you road race a tight course where shifting into 1st at speed is an issue.. and ot be honest some of the fasest people i've talked to run single synchro trannies shifing at 9k RPM only having a double synchro 2nd gear like stock (actually i think it's 93 or 94 and up that all have double synchro, but i know it changed design from 95-96 yp97 and up)
2nd is the only one I was thinking of putting the double synchro on. Mine is just trashed, so I haven't felt it shift smoothly to 2nd (like a double normally would) since I bought the car. I didn't help matters any... I have a really bad habit of popping 2nd gear to 3rd too quick, as the clutch is engaging, and I've felt those teeth get smacked quite a few times because I am in too much of a hurry to change gears. Really though, if the damn thing would just grab and switch as fast as I shift, there'd be no problem... it's just worn out. That's all. It's got a 130,000 on it, and the last 6,000 it's had have been me "playing around" with it, so I'm not at all surprised it feels slow and messed up.
the 2nd gear syncro is only taking wear when going into 2nd either up or down shifting, when going for the 2-3 shift the third gear syncro is what you're beating on. Either way i'd say your 2nd ger synchro is shot, OUt of the three trannies i pulledapart to get parts from the one with the dragging clutch but the only one with good non chipped gears inside had the syncro backs touching the gear faces (there should be a gap so the cone that does the braking of the gear can work)
MY advice is, If you're an above average guy with tools and working on things (say not afftraid to pull and engine down and re-ring it or what ever) then with a good manual and a few extra tools (press, gear/bearings splitter and somegood snap ring pliers, then you'll be able to build a trans they are much simplerthan you'd think, but if you don' read enough to know what should be in what condition and how to tell if something is in or out of spec then send it to Tim Zimmer, i'd say hands down he's the most helpfu, dedicated guy doing this that isn't just about how much you're spending. Hell he walkedme through building my own (of course i bought everything from him to show apreciation for the help) but i built a trans with used parts and new replacements of the things that are "must haves' according to Tim an it shifts every bit as well as my TRE stage 2.5 FWD did..i may not have the stronger gears, but the shimming, assembly tips and boost in confidence he provided me allowedme to do something i ALWAYS thought i'd have to send out to have done.. I was lookingat buying new clusters from jack's but due to Tim being the most willing to return a PM off usiness hours and talk to me like a fellow DSM'er and not a potential increase in his bank account I went and took the risk of doing it myself with his expert advice,and now i have two good trannies, well a "decent" backup that will at least drive if i break this one, and i plan to buy everything from him i need to make it into a heavy duty, great shifting long lasting tranny
I've always been loyal to those who help me out without wanting something demanded in return and that's what Tim did, so even if hisparts were to cost mor (and they don't) i would still buy them all from him.. but after dealing with him, any money i have to spend that can go to hi will be spent with him.. he taught me a LOT, saved me a good bit of money even though i was WAY over budget due to broken parts i didn't expect. I would say contact him for doing it for you or helping you along the way.. He has my business for life as far as i'm concerned and for being a man that's as hard working and gets as little rest as he does, yuou can't help but give him 110% of your respect and attention.
Hell,he's even the one that told me about all the stuff i wanted that i've seen on jacks and TRE that were basically gimicks (or just stock parts and nothing special thatanyeone can't buy) The DSM community is lucky to have such a person and i'm glad he's into the business he's into, and although as broke and crippled as i am I'll do all i can to help him grow further with whatever business i can bring him or parts i can buy from him
I looked at TRE, and that is actually where I was going to have the gear set shot peened. They look like they know what they are doing, for sure. As for what I meant by smacking the synchro in 2nd, if you shove on it going out before the clutch snags fully, it'll tick the teeth. You can feel it. I have also slammed it into gear from 1st pretty hard numerous times, because it doesn't want to cooperate. It's toast. I have no problem yanking the guts out of my car and fixing it, and I already welded up my own A frame bottle jack press (had some bushings on a old Jeep I had to smash out). I just finished rebuilding the motor from a crankwalk episode, and it is running nice and strong so far. I am not afraid of cracking the gearbox open either. Been there, done that, got the scar on my palm to prove it (old T18 + a prybar + beer = self mutilation). LOL
Don't know if you have tried this, but adjusting the clutch could help. Might want to test for clutch drag.
btwglenn, youve inspired me yet again. Every time i try to hit 3rd at 6k and get locked out i know im just that much closer to a rebuild. Im a good, technical mechanic and you make it sound like a guy like myself just might be able to do this on his own.
how much was the total cost so i can compare to what the local shop wants. I think theyre asking 750 for a complete teardown and rebuild, they do great work but i want heavy duty gears and synchros so doing it myself might be worth it even if the cost is the same. Thaks again and were all rootin for ya bro\!
btw, my tran has 201k miles.. its abouttime i think LOL
I have it adjusted out a bit more than most people would prefer, actually. The ball is shimmed out because I drove a Jeep Wrangler before this, so I am used to a long throw on the pedal. It isn't dragging a bit. I did the 7k no load check. It's partially how I have the clutch set up for my personal comfort, and partially because I tend to get jumpy and shove on it to quick when I'm "racing" it. Between the 2, I mess up synchros.
Thanks for the kind words everyone, My prices won't reflect most peoples becayse i didn't have to buy synchros or gears (had 3 donor trannies and each had a decent gear or two to use in them) I did have to but a new center diff thouh which puts me about where a rebuild kit it.. I spent 300 on a used trans with good gears and bad synchros (usually if synchros are shot badly the gear is bad too though, which i recently learned) Anyway, on top of that i spent almost 400 on parts, bought a bearing splitter, oils and RTV.. i don't want to know the real total, but i'm sure that Tim Zimmer could get youthe basic rebuild with 1-5 synchros, bearings, clips and seals for a competitive price towhat they sell for online (but ican't quote his prices)
I'd say with rebuild parts (the basics and any misc you may need) you'd be around 500-550 bucks, but you'd know it's done right and can shimit to shift like a race trans and take more torque..normal tranny shops don't shim, at least not to race spec,they just tossthe old shims back in... To make an honest guess if you need all seals, synchros, bearings, a press and splitter you'd still get away for less than the 750 tranny shop price, plus you'd learn how to do it and save yourself cash n the future as well as make a little off friends.. now when i see "trns for sale, slight grind" i think "mmmmmmmmm...parts!!!!!!!' LOL I would more than encourage you to do it and if i had a way there or you can get up here with the pars ahead of time (plus i'd have some spares is somethiong unexpected came up) i'd be glad to walk you through it, to help another DSM'er and pay it forward a little bit like Tim did for me.. I'm not trying tocharge people to work on trannies, (well i do loclaly but not repairing to this extent, mainly swapping them out or replacing bad diffs) but you catch my drift.. with parts, my buddies hoist (or you could donate a small autpozone one :D) and me guiding you i'msuire we could have itout, rubilt, back in and you on your way homein 24 hours....Once i fiured it all out and had all the parts, I assembled 2, installed one, trouble shot some shifting issues (bent selector where cables hook up)and was going hard in that ame 24 hours
My trans shifts better at 5k RM + than it does at low RPM when cold (just like my 4k dollar TRE did), i just went tothe store and the car was cold, tried toget 2nd to fast and grrrrrind!! tried again slowly and it was perfect, after getting tothe store, wamring up the car and trans the thing shifted beautiful everywhere and i'm usingcrap NAPA hypoid GL-4.. ONce hot or once i rev it though it shifts like itwas a brand new trans, at anything in the "racing" zone of revss it shifts like butter,, no lock out, no pausing, just slides on in :) I"m still a rtad scared to romp on third because that's when she failed last but it was a beat trans and this one is shimmed to take it but i just did a 1-2, then 3rd and let off pull taking each gear to a tad over 7500 and thr trans felt like that's the way it was meant to be run, no click, notch, grind or anything (which likeisaid, shifting too fast at lowRPM with it cold and you'll get a notchyness or grind, but that goes away when warm or as long as you shift like a daily drver should be shifted when cruising while it's warming up)
I say you sound like you can do it so go for it, just buy from tim (he's the best priced and most helpfull)
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
