turboglenn
- 6,375
- 123
- Nov 5, 2007
RIpley,
West Virginia
So far i'm not done, but this is a copy and paste from a peronal journal i'm keeping on the build for my own records.. it took 3 donor trannies to get enough good parts to not even need a single synchro (i think one donor had new synchros and hub shoes put in it over the last few years as they were allin twice as good of shape as the 98 i bought and had almost twice the gap between synchro and gear compared to even my good shifting units' measurements
I'll toss some pics up tomorrow when i get out and get the bearing splitter i need to press of the bearings that require a tool to fit in a very tight space to be removed (mainly input bottom by clutch end) and the intermediate top ones that arepressed againstthe gears that are built into the shafts they are on.
Here's my journal
P.S. I have built several trannies buy just fixing holes in cases and replacing entire clusters and other assmebld parts with units from other trannies, this one was taken down to every little part except pullin the front diff apart, Tim Zimmer is the MAN!!!!!!!! If it weren't for him i wouldn't have taken this on, but he gave me confidence in doing it on my own which I doubt any othertrans builder would do knowing it's less moeny they can garauntee in their pocket, but i'll spend everybit i saved on his labor on moreparts
here's a list of my parts list so far and estuimated prices based on variouse websites with OEM mitsu parts listed and priced
IF this goes well and shifts nice based on what i've been learning i think i might take on my buddies GST build that has horrible synchros and is stuck in 1st gear.. He got so fed up with the car that he parked it and replaced it wiht another cheap car because h couldn't afford to get a trans and risk that money on a 275k mile car.. I"ll do the labor for him free if he buys parts and we'll see how that one goes.. And why it'scheaper for him to replace instead of repair is that the trans had something happen to it like 3 times in 2 years where we had to tear it out open and inspect/cleanand re-assemble with only a new clutch each timet to get itgoing nad it would last but not long, now hopefully with the hours of reading FSM's on these trannies i cn troublehsoot his for real and get him back in the DSM game
Here's my journal
T.G.'s Trans build from scratch said:Trans build
Tear down and strip and inspect leftovers from 2 trannies with damaged gears and one with smoked synchros
Ended up making 1 good CD from the 3 and one welded CD (rest parts junk) (98 had trashed spiders and brass ring) My old 95 had smoked oil ring (welded up solid) but rest was pefect, (caught just in time i believe from lack of damage from this) swapped the 98 upper CD cover and side gear into my 95 housing with good brass oil ring and good spiders, endplay is at the factory spec
Used the 1st and second gears, synchros and hub/slider from the 95 donor that had light damage but chipped 3rd input on intermediate, put these on the 987 intermediateshaft
Used complete input shaft for it's gears, synchros, hub/slider & shoes only from the 95 grenaded trans in my car, pressed onto the 95 donor input shaft and isntalled in the 98 cases
Used shift forks from 95 donor (looked brand new)
Used 98's shift rails, used my old 95 blown trans for it''s fith/reverse gear/hub/slider and fork
All VC's were good, have a spare now![]()
All output shafts were good except on 95 donor, so I can run either the 98 with 57 tooth ring gear and it's t-case or the 95 with 58tooth ring and it's t-case, I believe I"m gonna run the 57 tooth diff gear and 98 t-case becayse the only case damage i took in this was from a piece of third (a gear tooth) got wedged between the front diff ring gear and bell housing and knocked chunk out of bell housing (I figure the 57 being smaller although slightly, will leave a LITTLE more room between it's self and the case should i have an issue in the future, thus hopefully preventing anything that gets down there from being forced through the cases)
The only things i have left to do (once i get bearing splitter tomorrow ) is to push the bearings off the bottom of the input shaft and top of the intermediate shaft and replace all with new pieces and then re-shim the cases (gotmy specs i'm gonna use, just need solderand then to order shims)
Overall i'm very pleased.. I"ve rebuilt and repaired many trannies in the past but this was the first time i split the clusters and installed new parts, Tim mademe confident in what i was doing and dispelled some myths i was basing my fears off of, and i can say that I am 100% confident that aside from being a completely 100%stock rebuild with it's inherrant weak 3/4 hub and gear sets, that my tranny build will be up to my standards for shifting and general oem driving quality (assuming shimming goes good)
I"M also getting a clutch disk in the morning to make the input shaft "holder tool" from so i can torque the end nuts to spec without the penny trick and then i can re-install the end-case and install the transinto the car
NOw the shims i will need along with the other parts i'm replacing (if none of the shims from the 3 donor trannies will suffice) Will all take a few days to get here delaying much progress from this point on for a few days, but i'd rather know that every seal and bearing in the trans is fresh with a long life ahead of it, than to look at the driveway when i leave the day after getting it in only to notice she's puking gear oil on the driveway from an overlooked piece of 7 dollar rubber...
I've been able to keep costs really low on this and i HAD To, no other choice, but since i did stay in budget i can pay my speeding ticket (88 in a 45 - just built boost in third and let off, my speedo hadn't passed 80 yet) Btu i may also be able to update my ACT2600 PP with a new/used unit and hopefully get a new disk for it that will take some abuse comparedto the organic RPS full face that's in there now (As soon as it's hot from me slipping off the line i know i might as well let out becayuse it will smoke through the next 2 gears and slip like mad)
I'd like a SB unit but i know i don't have 200+ for a disk alone (would have if the trans didn't blow, but i would have had no reason to pull the trans to put it in, everything's a catch 22)
turboglenn's parts list and estimated cost for build so far said:this is not counting trans cores, fluids and RTV for cases (and other incidentals like the bearing splitter i have to rent/buy to complete it)
both CV oil seals (driver shaft seal, passenger CV)
16.00
output shaft oil seal (output shaft to t-case seal)
~ 7.00
input shaft seal (one that goes in from inside) 8.00
new rol pins for 1/2, 3/4, and 5/R forks (Jakc's for 1.00 each = 3.00
new shims inside center diff (need the brass one and the other side silver one) Aprox guess of 8-12 bucks
new Viscouse coupler snap rings x 2 ~2.00
new shaft snap rings (however many i need) ~4.00
all 4 shaft bearings ~100.00
both shift forks (1/2 and 3/4) @ 25.00ea ~ 50.00
New TOB 28.00
Total by my guestimates is 230 dollars for everything + shipping
