My FP Green...Does this look ok??
I just installed an FP Green on my car last month. And I'm not sure if that's a red or not. The turbo inlet could look gigantic due to the angle of the picture. I know a couple pictures of the green before I installed it came out the same way. Only way to check is measure the inlet.... 3"... you have a green, 4"... you have a red.
The inlet is 3" Here are more pics...
I went over to ams and they said that it was a deifinately a 60 trim. ....minmal shaft play...no in and out play....AND lTS READY TO ROCK!
I am sorry but if you wanted a Green, you got a Red. There are no if's and's or but's about it.
That compressor wheel has 7 blades... its a 60-1.
a 50 trim only has 6.
you have a ported clipped, 60-1 Red model turbo capable of supporting 550 whp or so.
don't plan on seeing full boost before 4500rpm or so.
Well, ive got all the supporting mods....i already picked up an o2 housing and now need a wastegate.
Im gonna use it and see what happens
Now for the white part again. When i removed my t25 on my 95 to upgrade the turbine wheel was whiter than a ghost along with the wastegate flap. Then when you look thru the exhaust ports you can see my plugs were white as a ghost. No race gas or leaded has ever been run through there, so i'm gonna say the white is due to a lean condition a few times, makes complete sense to me. Carbon is darker than that.
