My car is eating turbos!!!
mitsubishimanic
371
Nov 4, 2010
clarkston, Washington
Ok so two months ago I snapped my stock turbos shaft in half. The exhaust turbine was just chillin in the o2 housing. Don't know what happens. Well I got a 16g and a tubular header two weeks ago off a friend cheap. It was great no play at all he had used it for a year before he wrecked his talon. Well I put it on mine and all was good. Well today I go out and start it and let it warm up and drive off every things normal. I have to give it a little to get out in to traffic and notice a weird noise then it goes away. Later I gave it a little boost and it's whining bad. I go straight home. Let it cool down and check for shaft play and it's bad. What could make a car eat up turbos.
I think it is an eBay it says evo 3 tdo5 16g on it. Dosnt a true 16g just have numbers on it. And I don't think I have any oil pressure because I started it today and the litters are tickin so loud. I pop my oil cap I don't see any oil in the head and kill it and now here I am. I'm going to get an oil pressure tester today. Any input sounds like a bad oil pump?
Oil problem/or junk ebay turbo. Get you a good turbo and then double/triple check your oiling issues. Remove the oil drain and ensure the is no blockage and then pull off the oil supply portion and check for blockage. If nothing found, assume bad turbo and go.
It's deffently an oil supply problem I'm getting very little oil if any to my head it ticking like crazy. I poped my oil cap off and I don't see any oil flowing. my gauge is reading norm on warm up and warm. Could my gauge be reading wrong. Could my oil pump be bad. What else could cause oil supply/pressure problems. Also what do mean prime my 16g?
Oil pressure is very low at the head anyways, what kind of oil filter do you have and how old is it? Ive seen a certain manufacturer's (cheap ones and orange ones) filter material break down and clogging oil passages. just something to check and its easy to take a filter apart to check.
k well i got my oil pressure gauge working again and its reading inbetween normal and the bottom line so at least i know i have oil pressure some what. so now ill check for blockage any other suggestions of causes and where to start looking.
stock 10
ok so i did a lil diggin today took off my return line it wasnt collapsed or cloged. drained the oil and took the oil filter off couldnt see any thing abnormal but the oil had a lil metal in it. when i put the oil in the milk jug the lil bit of oil still in the drain pan had what i would describe as metal glitter. it was just a tiny amount. also i started a few days ago on a warm day see if it helped the tickin it didnt also i noticed i weird whirring or whine when i reved it .
Something's obviously failing if you're finding metal in the oil. Sorry, we're not able to aid you in tracking down major internal engine damage over the internet. Time to put on the big boy pants- drop the pan, start checking bearings; replace anything that is out of spec. Change the oil again once you're finished and hope for the best.
