1G my 1g gst will not display codes.
fupkid
May 22, 2014
farmington, New Mexico
I tryed jumping the connector and I get nothing from the cel. Can someone give me a hand.
Hook all of these sensors back up to the codes assigned. If you still get these codes, either the sensors assigned to these codes are bad, or the ECU's drivers that runs these sensors are blown, which curtails a rebuilt ECU to solve these issues.
13-Air Temp Sensor .. located in the MAF
21-Coolant Sensor (this is a common sensor that loves to fail causing major operational issues)
25-Barometric Sensor.. located in the MAF
-Good luck-DSM
if I ground one of the wires and the gauge jumps to full hot that means its the coolent gauge. Am I correct?
