MPD(MAP) Sensor
omgitsbao
May 27, 2013
Windsor, ON, Canada
alright i know its pretty stupid question but this was my last resort
my car hasnt been able to rev over 4k, either in N and rev-ing wont go past 4k
or even when im driving it wont go past 4k.
i have read on the forum that this can be caused by the map sensor or if you will mpd sensor.
so i took a look and found out that the sensor on top of the throttle body was unplugged.
the only thing is ...... where the hell is the pigtail... i cannot find the connect if my life depended on it.
could it be plugged to somwhere else cause the car does have a standalone ems.
so if anyone could give me ideas where to start looking that be great..
again i know ... stupid question but ima noob when it comes to dsm
use to civics.
thanks.:D
The Mdp sensor is on the Intake manifold, not the TB. I dont see how the mdp will cause this problem. As far as i know, its only emissions related.
Only sensors on the TB are the IAC / TPS.
You should check your spark plugs/Maf.
Are you able to build boost? Do you have your emissions lines deleted with the egr still on the car? If so, it is possible that the egr valve is stuck open thus dumping air out the #4 exhaust port. Not sure if this would limit the rpms you would be able to rev to, but my egr valve was stuck open and I wasn't able to build more than 2psi. It's worth checking out because if this is the problem, a block off plate is $15.
  • Wanted ISO Leveling valve assembly, Mitsu part MR135668
    Just bought a 98 Eclipse, while removing the fuel tank I accendently broke the Leveling valve...
    • briang26
  • Wanted 2g Trunk/fuel door release lever
    Looking for a 2g black fuel door/trunk release lever in good shape
    • jesse12345
  • For sale 2g parts
    Evo 3 Big 16g, xs power t4 manifold, various other parts
    • heresjimmy42
  • For sale 1G ETS street core
    1G ETS street core- USED
    • ist dwa
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
