map sensor?
Spydergst97
54
Oct 8, 2005
chicago, Illinois
i want to use dsm link but i really need to eliminate that maf. and i would really like to have a map sensor. where can i get one and how much?
Or if you think you are going to go all out, then get the GM 3.3 bar map, and wire it into the existing EGR harness.
ok, i was doing research on this and i found out that it'sonly to log your car with. is this right? i talk to jeff (dsmchips.com) and he told me samething.
i just wanted to eliminate the maf period. what about that maf t pro? speed density. hks vpc they don't sell anymore from what i heard
To eliminate the OEM MAS.......either a MAF-T or MAF-T pro are going to be your best/easiest option.
Correct the HKS VPC is no longer made, "used" is your only option there. If it was me, I would not consider the HKS unit as the MAF-T is more current technology for the DSM.
