map sensor
bucknasty88
37
Sep 4, 2006
Cherry Point, North Carolina
hey i was reading on hahn racecraft about 3 bar and 5 bar map sensor exactly what is that and is that the same a an fdc?
MAP sensor = manifold absolute pressure sensor. As the name implies, it measures absolute pressure in the intake manifold (or where ever you have the sensor located). What that does for me............it allows me to wire the sensor into DSMLink with a 0-5v analog signal in order to log this variable and to double check the "calculated" numbers I'm seeing inside a log with "real" numbers for a more precise tune.
I don't know the application that HAHN is using it for, so I can't say.
