MAP sensor
okm12346
565
22
Dec 3, 2007
Chicago, Illinois
For you guys with stock ECUs that want to run 1g head and manifold, or Cyclone, or Evo3 manifold, I found a solution for the MAP sensor. Instead of buying the adapter, you can you 97 Hyundai Sonata, with 4g63 DOHC, MAP sensor. I just got it from the junkyard for 2 bucks, i told them it was a solenoid. Anyways, here are the pics:
Im going to look at the wiring diagram for 97 Sonata and see if wiring is the same, or Ill post pictures if its not. Its a mistubishi part for the record
Sorry if repost
It *might* work. The 2G MDP sensor only works over a very narrow range, to see if the EGR system is functioning. It watches for a drop in vacuum when the EGR valve is opened. If the vacuum range matches the 2G MDP fairly closely you have a good chance at it. Nice find.
