Detail
Supporting VIP
- 525
- 134
- May 28, 2003
Marietta,
Georgia
Just finished my third (and definitely best) headlight retrofit in the 2gb headlight. My OG hid retrofit was one of the first ones on the site back in 2011. I’ve run into a a bit of a problem. I believe the 2ga headlights are negative switched system and my new led headlights are positive switched. Meaning, turn the lights on, and nothing happens. Can you help me figure this wiring out? I almost burned my headlight up yesterday and I think this will ultimately be the very best headlight setup for our cars for years to come.
This is the led projector I am using. Basically the 2026 Cadillac of projectors. It has a low and high beam using positive switched 9006 connectors for each high/low. MLED 2.0 from the retrofitsource.com
Projector
I’ve used these harness’ on other builds before that leveraged h4 sockets. Wondering if I can covert this to 9006 style?
Aftermarket h4 harness
Thanks in advance!
Projector
Thanks in advance!
