LED Circuit Diagram
spyderdrifter
5,426
860
Jul 11, 2009
Somewhere in, Colorado
I can't seem to find circuit diagrams for these type of LEDs. I need to know how they get wired up and what type of resistors they require. I want to change my LED gauge and hvac setups but my research for these has stopped. Any help would be appreciated.
A quick search yielded me nothing either. Fastest response will probably be to click the contact button to email Chanzon. Due to the time difference, it will be about 24 hours for a response, but it is still probably your quickest path.
Here ya go, some info for wiring.........
https://www.homemade-circuits.com/replacing-conventional-automotive/
Looks like they produce heat that requires a sink but nothing more than a pc board that isn't etched for dissipation. I hadn't seen these before but I'm not in a field where I'm exposed to them. Evidently much brighter device than your typical LED. :thumb:
Marty
A fast way to test them if you have the leds would take a 2 AA batteries and put them in series to get 3v. Then take a 150ohm resister then probe the pins. A diode only has 2 pins so on this LED 2 pins are just holders. With the LED being clear you should be able to look on the back and see what pins are to the diode. If you want to have 2 volts instead of 3 use a voltage divider calculator online and it will tell you what resister to use to get 2V.
Thanks Nick! I thought I was that old guy that uses AA batteries for tests. ROFL :thumb:
Maybe 470 ohms in the final circuit at 12 volts. 150 ohms should be fine when testing at 3 volts from two AA batteries.
Looked like I could build a set of variable bightness headlights for my pop ups on my 90s that I own :cool:
I didn't realize all of those are RED....assumed white or various colors, depending on model.....now my FACE IS RED OMG
Was the write up helpful? I hadn't seen those before but understand them after I found that link I posted. Pretty cool LED's.
It wouldnt take much to build them. Very simple PCB design. Just buy a set of cheap ebay housing to put the pcb in. The big thing is what is the lumins output needed to be effective.
Yeah it looked super simple. I was thinking about reflectors too since the LED conversion I did on my 92 worked well with a good reflector in the lens. The thing I don't like about that mod is the noise that my radio picks up from the small dc cooling fans.
