2G MAP Sensor fault
Mts97Et
Dec 1, 2007
Chico, California
hi,
i have a Mitsubishi Eclipse gs-t 97. recently, my check engine light is on. i took it to midas and they did a diagnostic check and they told me that mine map sensor is the cause of the problem. So i had them change my map sensor but half an hour after the light came back on. they thought probably the map sensor they ordered is defective, so they ordered another map sensor. They changed the first one to the 2nd map sensor and it still has the same problem. They also did multiple diagnostic check and they still get the same code number which is the map sensor code. Please help me if you have encounter this kind of problem before or please give me some advices what should i do.
Your car doent have a MAP sensor, it has a MAF. Go to Autozone and rent a OBDII scanner, it will tell you what is wrong.:dsm:
I have always had to rent a scanner, but i dont have to pay for the rental tool, I just put it on my account.:dsm:
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
