maf translator help for a newbie
ratatack
723
Mar 18, 2009
Oceansprings, Mississippi
ok so i have this major problem maybe some one can direct me about it. to start out with im new to the dsm world i purchased a 97 eclipse gst spyder that needed new rod barrings upon getting it i decided it would be wise to have the whole engine overhauled and have the crank turned or replaced and so on well i dont knw anything really about this car i got it bc i was in need of a car and i was tired of hondas and wanted something new and would get enjoyment out of i paid a guy to pull the engine and take it to a engine shop where id have the work professionally done with a warrenty and so fourth 2700 dollars later i get the engine back in runs mechanically sound but has a idoling problem i get it home and realize the black box (translator box) isnt hooked up (this should be the idoling problem i have? ) i dont know about this box this is where i need you guys help for advice in hooking it up right and i can get it tuned id really apreciate all the help i can get bc i dont know what im doing i have a friend that semi knows but needs some guidance bc he has never seen a translator box like this bf HELP
:ohdamn:
If you still have the stock injectors, reinstall them. Without the MAFT to lean them out, you are going to be blowing way too much extra gas out the exhaust, washing down the cylinders, fouling plugs, etc.
Whenever you check the timing be sure and ground the terminal I believe its one of the three plugs located up on the firewall you posted a pic of the connector earlier. If you dont ground it like in the VFAQ you will see erradic timing.
Judging by the mechanics scribbling it looks like the cams are 264/272 im assuming he actually measured them by his math but his chicken scratch is hard to see. It looks like your on the right path though.
Good Luck :thumb:
-Kolby
EDITED
So your telling me there is no way to check timing on a 2gb? Thats odd I guess alldata is incorrect on that one, which doesnt surprise me I told you how they incorrectly reference some of their illustrations.
So you cant inspect timing with a light on a 2gb 97-99 :confused:
Wow if thats the case im glad I own a 2ga. Thats obsurd that they would abandon the connector idea. Its used on alot of early GMs as well as the 1g's and 2ga's... I wish I still had access to my alldata to confirm. So there arent any timing marks on the lower cover or anything? I guess I could understand to an extent since there is no physical to adjust base timing on the 2gs but still doesnt make sense as to why the 2gas and 2gbs would differ that much in the wiring.
Sounds much better after adjusting the cam gears. The cams aren't stock, but I'm not sure what they are. That head looks WAY too clean. It doesn't look like your oil pump is doing anything. I can see drops of oil here and there, but it's no where near as oily as I'd expect. And I'm looking at that image and see white chunks in your head around the lifters and oil ports - any idea what that is??? Any way you can verify you're getting oil moving?
You do have oil in there, correct? And there's enough gas in there?
I think you should also pull the plugs, see what's in there, see how they look, check the gap, and possibly replace them pending on all of that.
If so, I think the next step is probably checking the timing marks. If they're off, redoing the timing. If they're correct, doing a compression test.
the car hasnt been driven when i had the motor rebuilt i had to replace the oilpump it has a new one installed i dunno if thats sum of the reason why there isnt much oil in there and it has oil and gas in there as for the head being so clean the previous owner had the top end rebuilt i really dunno what to do with getting this car going im so stressed over it all of you have really helped out so much we have gotten further and further bc of you guys thanks with the advice keep it comming i can use all the help i can.
That white substance is white lithium grease (I'm assuming from the machine shop... :idontknow:) I think the reason the car's head is clean is that it only has about 2 miles on it since the engine rebuild! OMG It does have fresh oil, gas and plugs... I guess we're on to verifying timing and compression next...
I haven't recirculated the BOV because I do not have the factory bov or piping... :sosad:
Thanks guys... :dsm:
S
update for everyone (she runs and idles) as far as the problem boost leak test was ran and was getting serious leaking from under the intake manifold, after removing manifold had found out that manifold had been port matched to head, and the air was escaping under the stock gasket, fixed it and timing was WAY OFF!! Adjusted timing back to zero. The belt is MUCH tighter over the gears (was a little loose before) so the oil pump should be supplying sufficient oil. Car does run a lil rough, so now we will try the translator because it's currently running stock MAF and we put the 560's back in once we found the boost leak. We'll keep you posted and put a new video up. THANKS TO EVERY ONE FOR THEIR INPUT ...WE WILL CONTINUE TO KEEP YOU POSTED UP ON PROGRESS.
