_Madman_
- 327
- 1
- Oct 14, 2004
Riga,
Europe
Hi, I have done quite a bit of research, but in the end I still guess it's better to ask, because every setup is different. And the community here can help me from doing big mistakes.
I am ordering a 3'' downpipe and o2 housing (Megan racing) for my car, and I was wondering what should be the next upgrades to plan for.
Basically the car is still stock'ish, but I have 4'' FP intake pipe, boost gauge, recirculated Greddy RS bov, Hallman MBC, 5zigen exaust tip (the last can), Greddy intercooler piping UICP & LICP, I have a 8 gauge wire ready for the FP rewire, and I also have an Apexi power intake.
Since I'll get the downpipe with o2, I can also throw out high flow cat, downpipe and o2 housing parts from the 2G upgrade list, and that leaves me only with catback, turbo, FP and exaust manifold steps to go for stage 1.
The car is running at 16 psi as of now, that is the boost pressure I got after removing BCS restrictor, and so I left it at that with MBC.
So what should I do next?
There are many ideas, but none of them are verified, and I like parts to be verified and solid.
1) I would like to go for 16G big in a near future + install kit
What I doubt here is, what will happen with the driveability, I have a GST, so there is a big problem with traction. Also what sort of rebuild will I need for LICP? How awfull the turbo lag will be with this turbo if I'll just bolt it on current setup and will it heat the air less then T25 I have now?
2) I was thinking about upgrading the exaust manifold with this one "Forced Performance DSM Race Manifold" EXTREME PSI : Your #1 Source for In Stock Performance Parts - Forced Performance DSM Race Manifold: Mitsubishi Eclipse 90-99
But I also have no idea if this is the best manifold. It is supposed to be heat coated, so that should help a little, but there are some tubular designs, and some say they are better.
3) Cat back
This one is really expensive, with shipping it is around 800$, so I'm still thinking If I can just leave it for later.
4) FP
With rewire it should work for now, won't it?
So these are the ideas. I don't know what should I plan for next, and I don't know how the car will respond to those upgrades.
Right now heat is a bad factor, but intercoolers for 2Ga are ugly and expensive, so if I can I would like to skip that for now as well. 1/8 mi times are going anywhere from 10.033 to 10.600 secs on my car right now, street tires. But I haven't shielded the air filter from the engine, and maybe there is some way to get cold air here (designing a heatshield is a little bit complex with 4'' intake pipe and recirculated bow + aluminium pipes)?
The car is a daily driver and I would like to keep it as much sleeper as possible. Performance target for me is to get it somewhere where stock BMW M5 (before E60) would not be a problem in 1/4 mi drag.
I also have a 98/99 ECU that allows to do serious data logging, but I cannot use it because of the inverted CAS, I hope I will be able to flash it later on.
So, what would you suggest me, how much money will I need to reach the 1/4 mi ET target and what parts I will need that I haven't mentioned?
Thank you!
3) Cat back
4) FP
Thank you!
