Transmission planning for 2.3 build
milkandoj
Aug 12, 2008
Perth Western Australia, Australia
After a few yrs I'm planning my GVR4 1G stroker build. Running a t3 bep hx35 and later moving to a hx40, on pump gas only, 25-30psi. Like to think I'd be in the 450-500whp range... Ive broken a few box's on the 2L so Ive sort of learnt I need to be a tad more forgiving. The box I'm building will have 4 spider Center diff, upgraded selector forkes and a freshen up, so basically like a stage 2 or 3 build but not doing the evo 3 3rd and 4th. Strokers tend to strip 3rd and 4th with the torque so what are people's experiences on similar setup? The clutch I have is a clutchnet 6 puk and the 2X (2500lb) plate. Is this likely to be ok or would I need to move to the 3X (2800lb) plate?
Why don't you go with the HD gears 3rd and 4th, plus the HD 3,4 hub&slider.
They are the strongest gears on the market, stronger than the EVO's.
The disadvantage is they are not double synchro.
Check Jackstransmissions, he is selling them separately.
Yeah thanks I've seen that jacks sells them. I've been looking at what jacks, tre, shep do in their various stages. What I'm asking is are standard 3rd and 4th strong enought with a 450-500whp stroker? Car is a dd and will do a few drag runs a yr.
Well I haven't run any of those yet. But they say HD's are good for up to 700hp:
"PLEASE NOTE that the HD units we offer are the strongest synchronized/helical trans on the market! Capable of 700hp without breaking, these gears are the best we have to offer and are stronger than the EVOIII. If you constantly break gears from our competitors, then the HD build is for you!" - Jack's website
Depending on which tranny you have, you will most probably have to change the intermediate shaft as well.
I run a Shep stage 3, with 4 spider, quaife front LSD. The act 2900 sprung 6 puck combo is rated for 570ft lbs (at flywheel) which wasn't enough for my setup. Could not get it to hold more than 494ft lbs on the dyno. The clutchnet will likely need to be replaced if you want to put all the torque to the ground. I sold my setup to switch to a twin disc.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
