2G Limp mode
Iceman8079
51
Mar 1, 2023
Walton, Indiana
Looking at buying 98 gst 80xxx miles couple upgrades buddy says it goes into limp mode won't go over 20mph is car worth 1000 no rust anywhere
You could replace the factory transmission computer with a ForcedFour shift box for around $350. It sounds like the factory unit bit the dust. Check all wires going to the transmission (pulse generators, kickdown servo etc) for broken places or not connected. Those will throw it into limp mode as will capacitors going bad in the TCU.
I am not sure if there are remanufactured units available but I did find THIS ONE and I have a MD762042 TCU for a 97-99 FWD around here somewhere. Let me know if I can help anymore. If that is all that is wrong with it, it sounds like a deal you could pick up and use or flip.
Marty
Limp mode in the automatic transmission or limp mode in the ECU?
Can the ECU also go into Limp mode @steve ? Another thing that I wasn't aware of??? :hmm:
Ah hah.
ECU Limp = Open Loop Operation
Thanks, now that makes sense. :thumb:
So I bought a 98 eclipse gst. Owner before said it won't go over 25 30 mph. Replaced map sensor no boost leak or vacuum leaks anywhere. Just wanted to see thoughts on maybe the old cats being bad would cause this issue.
Don't guess. Obectively diagnose.
Any codes? Do a boost leak check.
Followed by compression. Leakdown. Etc.
At least do some basic diagnostics and tune up.
Ah hah.
No, ECU Limp mode = CEL on. Depending on what failed the ECU will do different things, IIRC the FSM describes the various faults and how the ECU limps from them.
do you know if a 1g ecu is similar?
Not as sophisticated as the 2G. This table is in the 1G 1990 DSM Technical Manual which every DSM owner should have and read regardless of what year DSM they have and if you have a 2G also read the 2G version.
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
