Low rpm limp mode?
AustinGST98
43
4
Nov 1, 2016
East Hampton, Connecticut
Hi, I currently own a 98 gst. I have ecmlink v3 and my ecu is fine. My car idles perfect but i have one issue. When i hold it between 1/8 to around 1/2 throttle, the rpms go from approx 1800-2000 then drop go back up again and again. This occurs in neutral and when the car is rolling. When creeping it makes the car buck. When i give it more throttle it just goes up and down at a faster rate.
Whats weird is that after that point, (approx half throttle) it will rev perfectly fine, what could possibly be the issue? It seems that my car is pulling my ignition timing, and it will go from 6 degrees to 22 degrees and back proportionally with the rpms, like, for example, if i keep it at 1/4 throttle
Yes, I believe so, haha. It was in the category with rpm and tps adjustments. It was selected by default, so I hadn't bothered to uncheck it. I guess the 2g throttle body has an internal idle switch, the reason for the fourth pin on the tps plug.
