PokinatchaPunk
- 328
- 5
- Aug 9, 2002
Fort Walton Beach,
Florida
So first off... admittedly electrical work is my weak area of knowledge. So bear with me. I was in the process of tapping on of the fuses on the interior kick fuse box and accidentally grounded a wire which then created a nice little spark. Sadly the result has created some issues.
-Switching on the headlights will occasionally set off the horn (only can be shut off by disconnecting the battery).
-Switching on the headlights will then result in the lights staying on.
-Dome lights don't turn on (either by switch or by opening the door)
I've done a review of some the similar posts and checked the common solutions
-100A Alt Fuse is good
-No fuses are blown (interior fuse and under the hood fuse box)
-Relays on fuse box seem good
-Initial check of wires under the main fuse box hasn't revealed any fried wires (haven't separated wiring harness completely though)
-Checked to see if dome and headlight bulbs were fried... nope
I thought it may be that the interior box itself could be fried but after replacing it...no changes.
I did notice that I could turn on and off the lights while the interior box was out and the horn wouldn't go off but the dome lights stayed off.
I have a Powerprobe ECT2000 to help track down the direction of grounds but honestly it hasn't been much help. I'm probably just dumb.
So there you have it... So besides telling me I'm dumb (I know that already) does anyone have any ideas? Any help would be appreciated. BTW... if any one is in the SF/Sacramento area I'd be willing to pay for assistance.
