99gst_racer
Moderator
- 12,010
- 1,706
- Apr 5, 2003
Coloma,
Michigan
I'll see if he'll let me snag a few pictures tomorrow afternoon.Paul, please post pics of said downpipe and car.
, Im just trying to get everything sorted out and get my car to the track Saturday, My v-band flange warped on me so im going to have to get another one and re weld it onThanks for the reply. I already have the Jays racing relocation kit, and as for the oil filter, and local guy in pa setup his 4" downpipe to fit with the normal oil filter housing, so im going to shoot for that. I use evo oil filters so it should fit, and be able to come off when oil changes are needed it. Im sure ill end up relocating it eventually.
The only thing with aluminized is that im wondering if the joints will start rusting. The v-bands are going to be stainless so i have to put that into consideration. Im not a professional welder, so i like personal opinions of guys that have done it.
Ok why a 4 inch downpipe? I was thinking of doing a 4 inch downpipe, and 3 1/2 after the v-band.
Why not just go with a forward facing oil filter housing off a mighty max? From the looks of mine, you could fit a pretty good sized downpipe in there with it.
Alot of it is just cutting some 10 degree and 15 degree cuts, and holding them together till it looks good. I used mostly 10 degree cuts. You use a chop saw and can set the degree of the angle before you cut. 10 degree cuts make more of a round turn then L's. You want it to be smooth and not abrupt, like it was ment to bend like that.
It takes time, alot of cutting, grinding, and fitting. It kinda falls together, and im sure the next one I make will turn out even better. Im happy this one works, clears everything, and the oil filter still comes off with no trouble. Its acually pretty rewarding.
