Knock sensor!!!
1992_Talon_tsi
384
Dec 20, 2009
MIAMI, Florida
Ok guys i found a few threads about it but none of my interest if anyone could explain with pics how the knock sensor wiring goes i know that the with cable gets the solid 12v signal from the ECU but i know its not it. If anyone could fine explain this to me i will appreciate it. O and btw this is for a 1g N/A engine with turbo witch i think the hole its threaded on cylinder 2...
Did you change out the harness and ECU for turbo usage?
Ok dont worry about the harness you dont have to change it, i just wires all the important things i would need for turbo convertion and of course im running a turbo ECU, 7th pin from maf, injector resistor pack, and now im in the process of the knock sensor. Ok maybe you guys are not very common with this, all i want is somebody to explain me how the wiring goes please...
Ok so for all the people in this situation all you need to do is run the white wire to the 9th slot in the ECU harness and the black wire goes grounded on the firewall! I already did it myself and everything its working great no check engines and DSM ready to fight knocks like a champ!
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
