- Ownership Status
- Currently Own
- Year
- 1993
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- GT35 Variant
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Punishment Racing FMIC kit, TIAL 50mm BOV, TIAL 38mm MVR waste gate on punishment o2 housing, Mishimoto radiator and fans/shroud, God Speed exh manifold, FP Red Turbo (journal Bearing), 3" turbo back exhaust, FIC 850cc injectors, AEM fuel rail, 6AN fuel feed from tank, 6AN fuel return to tank with Fuel Lab pressure regulator, Walbro 255 high pressure rewired, 6AN fittings on valve cover to catch can, poly motor mounts (solid front with tubular)
- Mods-Engine
- Rebuilt 6 bolt block, Clevitte bearings, ARP head studs, SCE Titan head gasket, Delta-Kelford 272 cams, MAP Beehives and TI retainers, 3g lifters, Kiggly HLA, Crower adjustable cam gears, gates blue timing belt, BS delete, Magnus SMIM, Throttlebodies.com rebuilt 65mm throttle body with half shaft MOD, b&M external oil cooler setup with 8AN push lock hose
- Mods-EMS & Logging
- AEM Digital boost/vac, oil pressure, volts and wide-band (simulated), ECMLInk v3 lite, Speed Density ( GM IAT and Omni 4 bar map)
- Mods-Drivetrain
- Red line fluids, new OEM slave cylinder, new master cylinder, SS line from master to slave, new OEM shifter cables, new shifter assembly bushing kit, Competition Clutch stage 4 unsprung clutch kit, new OEM clutch fork and pivot ball,
- Mods-Handling
- KYB AGX struts, Tein springs, Ingalls upper adjustable rear control arms, Jay Racing toe eliminators, bulFab tubular cross member (front),
- Parts Wishlist
- GT35r turbo kit, ETS FMIC kit, some sort of light weight rims and sticky tires, tubular front end and 8 point cage with chute, D2 coil-over kit, DSS drive shaft, DSS axles (front and rear as needed), double pumper with 8AN lines and 1800cc injectors to convert to E85.
Dyno Tune by Boostin Performance (home state shop)
All the above will be completed in the near future! Anything that is needed to run consistent 10 sec passes and be reliable on the streets for cruises and meets!
- Background
- Bought this chassis from a friend who was on his way to scrapping the car. Have completed a full restoration on the car and plan to keep it in excellent condition for years to come. I have owned 14 dsm's in the past ten years and this one is by far the longest lasting in my possession. May be due to having children now :) .
Plans for the car are to continually purchase or fab mods for it and my end goal is for it to perform as a 10 sec street car. After that, only god knows where it will end up!
