CrackedDSM
- 5,833
- 5,734
- Dec 17, 2009
Pensacola,
Florida
So, my MAF sensor was bad so I decided to bite the bullet and struggle with ECMLink's SD again. And I desperately need help. PLease...please help me guys.
Verified mechanical timing, timing set at 5* like it's supposed to be, fixed the boost leaks I found, mods in sig.
Problem: it will not idle with removing a MASSIVE amount of fuel from global, and doesn't appear to care what I do to the VE map in the SD tab. The settings that the MAF liked was -57 global and 275uSec of deadtimes. With these settings and everything else zeroed, it tries to idle at 10:1-11:1 AFR and hates it. It'll die out, and will not idle unless I hold my foot on the gas.
Out of desperation, I removed like 18% from global(down to -75%,
) and like a miracle it idles at the perfect AFR that matches AFRest, and etc. But I shouldn't have to pull -75 from global just to get it to idle.
So, attached below is the short idle log. It will not idle without me holding my foot on the gas, and the first bit of the log the (idiotically slow) LC2 wideband isn't warmed up yet that's why it reads 7:1 AFR. Please...please help me. I don't know why when I adjust VE it just ignores it and does what it wants, but responds to global. Can someone please post up a settings file that I can see if it'll respond to so I can see what changes you made? I just want to get the car idling like a champ with proper settings before Friday. I don't have unrealistic goals IMO.
