2G Is this my VSS? How to remove it?
KMJDSM
61
Aug 9, 2018
Riverside, California
All, I am not finding any threads with pictures of where the VSS is or how to remove it from the car. I have found threads pointing to it as a cause for speedo issues and threads describing what it is and the general area where it is located. One thread references a 10 mm bolt but I am not seeing this.
My speedo works until about 60mph and then drops to 0. I assume some of the teeth on my VSS wheel are eaten up causing it to slip at high MPH so I want to pull it to check. I know it is under my throttle body on top of my 5spd manual transmission somewhere.
Can anyone confirm that this is the VSS (arrows below). If so how is it removed? I don’t see any bolt or nut holding it in? Thanks
