Please Support JNZ Tuning
Street Build Change of plans(99 gst)
Ownership Status
Currently Own
Mitsubishi Eclipse GST
Turbo Type
16g
Drivetrain
FWD
Build Type
  1. Street
  2. Drag Race
Evo Big 16g, 3 inch exhaust no cat, FMIC, Urethane Motor mounts,
Mods-EMS & Logging
Ecmlink V3, PiLink, Speed Density, Innovate WB, Ethanol Sensor, Ingersoll electric boost solenoid, Boost oil pressure and fuel pressure Gauges
Parts Wishlist
AWD Swap, Cams, Bigger turbo, Bigger injectors, Catch can setup, "Cold" air inlet system for turbo, Big brake kit, Touch screen control for pilink, custom headlight/taillights
Background
Was a decent running car in its day motor took a hit and sat for several months before I purchased it. Was not my original plan project but things change so almost 2 years later and half into a 96 gst I began working on this one slowly as work allows me. I Have 95% finished the wire tuck on both the Body and Engine harness stripped out the engine bay layed some primer and getting ready for motor install. I tried to remove and delete or relocate as much as I can without drastically altering anything for now.
I'm gonna leave some pictured from the start of the journey till now and continue till the car is up and going.
Thank yall so much for your time and patience with me it means a lot, Jason Penny
JPenny
More in 2G DSM
Share this Vehicle
