Is this crank a good buy?
jdub099
5+ Year Contributor
41
16
Sep 2, 2019
Denver, Colorado
I'm going to be taking a look at this crank this weekend. It's been a LOOOOONG time since I even saw a DSM crank and I doubt the seller will let me bring it to a machine shop for a once over. He said it was from a car that spun a bearing but that he was able to polish it out. Is this an OK procedure? If you want to know what's wrong with my crank, it's an Eagle 100mm and if this engine goes, I won't be building another 2.3L.
I'm selling an 88mm OEM 6 bolt DSM crank. This needs 0.25mm oversized bearings.
I blueprinted the crank and the measurements are below.
Rod 1- 0* 1.7605” 1.7604” 90* 1.7602” 1.7606”
Rod 2- 0* 1.7604” 1.7609” 90* 1.7603” 1.7604”
Rod 3- 0* 1.7600” 1.7600” 90* 1.7603” 1.7601”
Rod 4- 0* 1.7602” 1.7604” 90* 1.7604” 1.7605”
Main 1- 0* 2.2335” 2.2334” 90* 2.2334” 2.2333”
Main 2- 0* 2.2334” 2.2335” 90* 2.2337” 2.2333”
Main 3- 0* 2.2334” 2.2333” 90* 2.2335” 2.2334”
Main 4- 0* 2.2336” 2.2333” 90* 2.2333” 2.2333”
Price is $180
Take a set of micrometers with you and measure the spun journal in front of him. Write it all down and take it to a machine shop.
Price is $180
Where you located? I have one i'm not using that has no wear what so ever. It's basically one I pulled from a block an old friend wanted and this one wont need oversized bearings.
