intake problem
motorzto
May 14, 2012
los angeles, California
I wanted to try out an ebay intake on my t28 2g dsm .. the results are it looks verry nice and the bov sounds louder too.but i dont feel the boost i used to on my stock set up.. i tought it might be a leak but i check everything already.. any help
Do you have a boost gauge installed? I know you said you looked for leaks but it is possible that one of those pesky vac lines could have came off the aluminum nipple on the intake. Have you checked for shaft play on your turbo when you had the pipe apart?
Leaks is a great thing to check for..
Your going to want to bactrck to everything you took off or unclamped.Like IC piping for one.
Big gain of HP with an intake pipe..Maybe a very slight increase, but not alot more by any means.
Its an injen style intake ... I checked shaft play before and nothing.. ive been checking my hoses but nothing everything looks good ... I wasnt expecting big hp gains just what i read that would hear louder bov, better intake feel and sound and faster spool up.. my set up was and still is re circulated ..
See if you can post a pic and make sure your maf is plugged in, and all hoses are connected nice and tight. Also get a nice K&N filter.
Ok il buy some clamps to tight em up and a filter .. and hopefully it fixes the problem... Thnx dsm bros i apretiate it ....
