Intake Pipe Problem
1990dsmkid
692
98
Jun 14, 2012
Bellwood, Pennsylvania
I have a 90 awd talon and my intake pipe is 3in ant not sure of the brand(came with the car). Now i bought new radiator hoses from napa and I have them installed but now when I put on my intake pipe it pushes into the lower radiator hose and squeezes it some. I know it would most likely be ok but I dont want it to. As anyone ever ran into this problem before and if so what did you do? The coupler on my intake is from lowes and I did search this but didnt find anything that goes over this and I cant post in the right forum as being a probationary member
I matched the napa hose up to the stock one and it is exactly the same. I thought about the coupler being the problem but just wanted to double check before ordering something incase there was a different issue. Its deffinetly not on wrong I checked that the other way was way worse. Thanks guys looks like this is just a simple fix with the correct coupler
fp is too step for my pockets for a coupler. Like stated a normal thinner coupler should fit and not push against the lower rad hose. It might touch it but not push against it. Ill just order a coupler and see what happens.
