Intake Install Problem
techmaster330
Nov 12, 2009
Cochranton, Pennsylvania
I just order my new intake from Dejon to fix my huge boost leak, well it came today and all it is 1 pipe with no way to hook it to the MAS. Is there some kind of trick to hooking it up or do I need to get a new MAS or what?
Are you matting it to a 2G MAS??? then Dejon should have supply the coupling for you. I had order a similar pipe in the pass and they have supply everything that I need for my Install.
I honestly don't know what is on the car, the PO never really told me so I don't know what MAS it has on it. I know that where the coupling should hook up its shaped like an oval so there is no chance the coupling I got with it is gonna hook up.
Please take a picture of what you received and we can do more than make educated guesses on helping you.
If you have a 2g MAS then yes. It's a common upgrade for the 1g fellas since the 2g MAS flows more and it's setting allow them to run a 550cc injector with very little tuning.
If you are new the the DSM world, it would have been an honest mistake. I would call them up and let them know what happened and that you need a 2g intake pipe.
