- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 16g
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- EVO lll 16g turbo
FP exhaust manifold ceramic coated
Copper exhaust manifold gasket
SS Exhaust studs STM
Thermal Research 3” exhaust
RVR intake manifold
K&N 4” air filter
CXracing 2g bolt-on FMIC
Spectra premium fuel tank
New oem roll over valve
New fuel gauge sending unit
Walbro 255
Fuel pump
-6 an tank to rail fuel line
Weldon fuel filter
Aeromotive fuel rail
PTE 880cc low z injectors
Fuelab adjustable fuel pressure regulator
Mitsumoto radiator
Mitsumoto slim fans & shroud
Mitsumoto temp sensor
Chase bay dual cooling fan relays
- Mods-Engine
- Oem crank
Manley 150 h-beam +625 hardware rods
Wiseco .020 over 8.5:1
King bearings
Oem evo MLS head gasket
- Mods-EMS & Logging
- Innovate lc2 wideband
Speed density w/ 4 bar Omni map
95 Eprom
ECM link V3
- Mods-Drivetrain
- None
- Mods-Handling
- Reman OEM rack pinion
RM sway bars front and rear
Jdm galant knuckles
Evo 5-9 brake backing plates front and rear
Evo 5-9 brembo calipers front and rear
Centric evo 5-9 rotors
3g Master cylinder/ brake booster
SS brake lines
New timken hub/bearings front and rear
Volk metal craft rear control arms
Cp30 18x8 +35
- Background
- Bought it from Long Island NY drove it home to central Massachusetts where I started maintenance and won’t stop till it tunable and ready for body work
