- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GST
- Mods-Bolt-on
- fp 2g highflow cast exhaust mainifold,
16g mhi turbo,
3" turbo back thermal research exhaust welded solid,
255 walbro (rewire & relay),
aem fuel rail,
pte 880cc injectors,
fmic (2 1/4 pipe & 3x7x30 core),
Greddy rs blowoff valve (non recirculating),
Dejon intake,
avid motor mounts (roll stop),
ngk spark plugs,
MSD 8.5mm spark plug wires,
FowardFacingFilter bracket ,
Aluminum radiator+slim fans+shroud,
Ble solid tensioner,
NEW
Alternator,
Starter,
Power steering pump,
Rack and pinion,
- Mods-Engine
- evo 9 pistons (.20 over)
6 bolt rods
oem mits mls (head gasket)
L19 headstuds
Comp 272
Manley singles w/ Ti retainers
Gates timing belt
new oil pump housing
Balance shaft eliminator kit
- Mods-EMS & Logging
- dsmlink v3
3" gm maf
sparco boost gauge
- Mods-Drivetrain
- 2900 act pressure plate
Street sprung
New slave cylinder
New master cylinder
New clutch fork and ball
New shifter linkage
- Mods-Handling
- 3g brake master cylinder,
3g brake booster,
drilled slotted rotors all around,
enkei 18" stagered 225 45 18,
All new font end components,
- Parts Wishlist
- Upgraded head, valve springs and retainers,strut bars, coilovers.
