Intake/exhaust valves(Vid+Pics)
jhunfiyell
69
Dec 12, 2012
williamstown, New Jersey
okay, i redid my valves, and let me know if i did this right. Thank you
click on the pic below. i tried to get the video to be able to play here
here's the pic for better details of the valves to see if its in the right position.
exhaust small? and intake large right?
What do you mean by "redid my valvels"?
They appear to be installed properly (small=exhaust, large=intake).
If you removed valves to be cleaned, then they have to go back in the same valve guides they came out from. If valves were mixed during reassembly, then there is a good chance valve seat and the valve may not not seal properly which will result in poor engine performance. Bring the head to a machine shop and have them perform a vacuum test on each port.
If you installed new valves, then valve seats must have been cut by a machine shop to match the new valves.
okay, i just needed to know if i had them on right, wasnt sure if it was backwards. but thank you!
okay i redid my large valves, let me know if this looked seated right, i kept lapping for nearly 3hours, just to make sure its lapped to perfection. let me know please
Sorry for thread jack, but I am also rebuilding my head and received new std. Stainless Valves. Can I just lap them into my existing seats or do they require machine work to the valves and valve seats before I install them?? The head had 140k miles and the factory valves were fine when removed and seats appear good.
I have had good luck getting new valves to seal without a seat grind. However, you should check your valve guides to see if they are within specs.
http://www.dsmtuners.com/forums/cyl...-do-you-check-valve-guides.html#post152308305
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
