Installing Innovate LC-1 WB
Dumond123
Aug 22, 2011
ny, New York
I recently installed my innovate lc-1 wideband but i can't get the push button and LED to light up, i havn't got my bung welded in yet so i have not calibrated it or anything but i will need to soon and im clueless on how to do so without the LED according to the directions, I am 100% positive i hooked it up correctly ive checked plenty of times, i did buy it used but slightly used and it came with everything, original box, cd, instructions, etc.. Could the LED be bad or is there another way i can calibrate it? Any help is appreciated thanks guys.
you have to add led and so on, in other way it will not work, it's 5 or 6 wires ? if you have 5 wires without led it will not work. also don't forget that you have to connect line in together, otherwise it will not work too.
i did add the led with the push button and the led doesn't light up.. Also i didn't hook up the yellow wire to the headlight power switch, but would doing so make it brighter during the day? Because i can barely see the LED when its sunny out.
front to back the led. one way should be infinite resistance the other way(reverse polarity) should be very low and using a meter will actually light up the led. do that, report back. if its ok, then ## wiring is no good.
remewmber, its a diode. current will only pass in one direction. simple as that. when u hook up a meter to check resistance you probably putting 9v across it. so when neg is to neg and pos is on pos, the led will light up. most diodes kick on at .7VDC
hope i made that a bit more clear
Wouldn't putting the o2 sensor for wideband in the o2 bung be to close to the turbo? Causing to much heat? And im using an engine ground so its good, can anyone give me some clear calibrating steps for the innovate LC-1.:hmm:
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
