1G Installing a turbo 4g63 into an NT 4g63
Mavisky, nice pics were you passed the wires through to convert the harness to turbo. My question is did you run those wires on the outside of the car or through the firewall? If through the firewall, how and where???
hi mavisky
you mentioned the bump in the crank needs some grinding to accomodate the nt flywheel. could we just bolt the N\T crank?
would it break? any strength difference with the turbo one?
I think i'm retaining the harness. too much labor to change it for the turbo one.
thanx for all the advice.
the crankshafts are indentical in strength and design. infact the nt crank has a hole where they simply didn't install the alignment pin (why i don't know).
while you could very easily swap them out it's ten times easier most likely to simply fix the pin situation.
Figured I would put my 2 cents in. Here is what I used for the additional wires needed for the conversion. The best thing about the conversion is that the stock wiring harness can be used with the addition of the extra wires needed. Here is the wire I used. It is designed for robots. I bought it from Mendohlsohns. www.meci.com I passed the wire through the steering boot.
Also, I have a lot of pictures documenting the project if anybody is interested in seeing them let me know.
Wishihadaturbo, really interested in seeing those pics. I am running my wires through a hole near the tranny cables? But i got a few questions?
1) Where did you buy pinouts to add the new wires in the harness??
2)I am running the wastegate solenoid wire, airflow sensor wire, and knock wire, those are the only neccesary ones right??
If you have detailed pics i would love to see your resistor pack set up, and were you grounded the knock sensor
I bought a turbo car from Wisconsin and swapped the engines and got everything I needed from the donor car. Here is another picture. Fuel cut pressure solenoid is the only circuit I can think of to add. Funny you should mention the resistor pack. I haven't added it in yet. I have cut it out. I was going to mount it in the stock location. There is a hole already on the firewall. I think I grounded the knock sensor to a bolt nearby on the block.
Here is a picture of the finished inside harness.
did you just pull the pinouts from the old ecu harness, or can those same pinouts be purchased somewhere. Great pics got any more???
i have been switching over my 93' Talon ES to a full turbo conversion. 6-bolt turbo block with turbo 2G heads and a 91' turbo tranny, stock NT intake man., decided to keep NT harness after three other swaps of harnesses DID NOT work out. It is at an electrical shop getting this work done and completed, because I hate doing electrical work. $1200+, up to over $5k invested into car, but it has been worth the last 10 months of work and knowledge learned from my car. Stock turbo being used with stock lines, and I hope to retain anywhere from 240-260HP, with upgrades over the summer soon to come.
5K for 260HP? Hummm...
I've spent around $2500US and still have another $2000 that I plan on spending on mods and I'm hoping for 330-350HP. Maybe I'm out to lunch, but it's my goal.
Haha. Lets get one thing straight. 5k spent. An investment grows and is worth more when you sell then when you bought. Just a little clarification.
Let me set this straight. Every dollar that is dropped into my car, every second I dedicate to perfecting my car, is all an investment. It is my investment, and its return may not be equal in cash value to what has been dropped into it, but it is worth every dime for the effort and pride it returns back to me. I never said I expected equal resale value. Who would sell their DSM? As for HP, for stock turbo, I believe this is a great estimate. You are looking at 300+ w/ an upgraded turbo I should assume, so naturally you can just drop on a 16G and get that. I have a completely different project car going than what you have, so naturally we will have some differences in value dropped and HP produced out of it. Just thought this moment of clarification could set straight some comments I saw posted in response to my post!
Originally posted by allwheelTSI
did you even read the thread,dude?
i'd say no, and not only that but this is the wrong thread even. look at the one for how to make a turbo kit for your car dimwit.
ahm, possibly a wrong thread issue but its not one at the top....
would anyone know anything about converting a 1.8l nt into a 4g63t...?
swap the whole front end maybe... ? :) Is that ecu similar ... the same....? who knows...
also... im a newb at this what is the difference between 6/7 bolt motor and what does this mean when doing the swap.... how would i identify a 6 or 7 bolt motor
thanks!
thanks!
with the 1.8 to 2.0t swap,you'll need a donor car: wiring harness,bottom crossmember(the one the points where the car is going),tranny,axles,ecu,the motor and every turbo related component on the car. theres probably more,but thats all that comes to mind at the moment. look around on vfaq,it'll tell you the difference between 6 and 7 bolt.
mavisky hoping you canhelp me out......I am taking the turbo engine out of a 93 and putting into my 90 nt. Because the nt was fwd it cant accpet the full awd system off of the turbo car. I also cant run the nt tranny because the turbo isa 7 bolt and the nt is a 6. My question is, can i run the awd tranny exclusively fwd by leaving off the rest of the system and transfer case and not experience any power loss? Or is some of the power always transfered to the rear wheels(non-existing in this case)?
I'm not 100% sure but scrap the AWD tranny and use the FWD one. It really does not matter if it's a 6 or 7 bolt, it should work all the same. Just make sure you use your flywheel off of your n/t tranny and pick up a heavier clutch from ACT or Centreforce. Keep all of your clutch related components that you can still attached to the car when you do the sawp and utilize them again when you use the n/t tranny.
Hope that helps. But wait for more responses to back me up.
you can use the awd transmission. the thing is you'll have to pull the transfercase output shaft out, weld up the hole for it, weld up the center diff on the awd tranny and use the awd axles. ( not so bad since you'd have equal length half-shafts then).
or you could simply hunt down the nt 7 bolt flywheel and use it since the only real difference between flywheels of the same model is the amount of mounting bolt holes.
if you get the nt flywheel expect to shell out around 200 for the new flywheel and about 300 for the nt clutch. or you could shell out around 800 and keep the awd flywheel and clutch, and do the modifications to the awd tranny to make it work in a fwd manner.
F*ck I'm stupid. You can't use the n/t flywheel cause it's a 6 bolt one. Buy a 7 bolt n/t flywheel and heavier clutch, and you'll be able to run your n/t tranny.
I am currently trying to convert a non turbo Sohc Neon over to a eclipse turbo. The only problem that I am having is where to start. I am going to have the exhaust manifold made. I have a turbo off an eclipse motor 2.0 Dohc. Where do I hook up the oil lines? Where does the boost controller set? Where does the BOV need to be? Am I going to need a bigger fuel pump? etc.
wrong thread buddy, this is for the 4g63 mitsubishi engine, not the chrylser 420a.
Hey how are you guys? I'm currently converting my NT GS to turbo, Wil and I got the turbo in with the MBC and a SAFC, but now I need the injectors in, my question is can I just swap the injectors or does the the turbo injectors work on a diffrent OHM. What is my next move? Thanks
Rev
if you want to use high impedance aftermarket injectors you can just swap them right in, but if you want to use any of the stock turbo injectors or aftermarket injectors commonly sold for the turbo cars you'll need to wire in the resistor pack i talked about in the main post.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
