installed camber kit (caster adjustment?)
DSMAvenger
41
Feb 18, 2008
SeaTac, Washington
I assume the answer is no but will the ingalls camber kit adjust the caster?
thank you
chris
Actually, it may be possible to create an angle in the upper a-arm by adjusting the camber adjustment unevenly, and that would change your caster. Isn't by design though.
It seems like it would though have no proof. I've had the kit for awhile and everytime i look at it I wonder. :hmm:
It's the driver's one isn't it? And I don't think that applies to his 96 anyway. Didn't that only happen on later year cars? I forget. My 95 didn't have it but my 99 did.
you can also do a slot i have ran into alot of alignments that have caster issues especially on strut suspension i have seen it all the best was a car i had come in last week an 2003 330i bmw that the lower control arm didn't have a bolt in it .it was held together with bailing wire
I'm finding that it's really 96.5-99 not 97-99 cars. I am unsure as to the cutoff date for what's a 96.5 though, and any help would be much appreciated as my car apparently needs all the caster it can get :(
Chris
well typicly a 96.5 would be a 1997 normally production date 06/96 and above would make the car a 97 i do stress normally Toyota defiantly does not hold true to this
Now i do know that you can go on eBay and that there is some type of catser adustment that is supposed to be bolt on as to the quality of these products i am unaware
this might help
Caster
Caster is tilling of front steering axis either forward or backward from vertical
when an axis is tilted backward from vertical , Caster is positive this creates a trailing action on front wheels .When axis is tilted forward, caster is negative .causing a leading action of front wheels
when you know which one u have u can adjust correctly
I have 1 degrees of positive front caster on the drivers side. A 96.5 model year is still a 1996 in everything I have read and every experience I have had with this. Why would it be referred to as a 96.5 at all if it were a 97 model year?
My driver side wheel is pulled towards the rear of the car noticeably and I am stuck in this newbie forum trying to find the answer because I don't want to flip the bushing if it's not going to help (and possibly hurt) my caster.
Thank you,
Chris
I have never heard of flipping a bushing to fix caster, and 1 degree positive in the front driver, is this what an alignment place said or do you know this for a fact?
Get under the car and look at the inboard end of the compression arm. If it has offset eyes on the bracket and if the offset is currently pulling the arm back, then you can flip the bushing for the extra caster.
There are some questions that are best answered by looking at your own car.
No, I guess by measuring the distance between the wheel and the backside of the fender.
Yes, it's on my alignment report. Geez, LOL
Thank you cinder.
Chris
