rear camber kit
MoyzGSX
Aug 5, 2021
Chandler, Arizona
any one know how to install this rear camber kit any help appreciate
remove the old bolt and bracket on the chassis. install this and then go get an alignment to adjust to suit. (whole car ideally) it is a very simplistic kit,
the washers can go behind the brackets but ONLY if you need to remove more neg camber but that depends how low you are and your final settings you require so make sure to take them with you incase.
once done up do them tight and then have them mark them with paint marker
