camber kit for stock suspension?
greezy
Feb 25, 2010
denver, Colorado
i have stock suspension but im getting terrible wear on the inside of my tires. I have searched through the threads and they answer a lot of questions, but i was wondering if i keep my suspension stock, what camber kit should i use? I am looking at the ingalls but not sure which would be best(and cheapest) i do have 18" motegi racing rims which i think is why im getting the unusual wear.
you can just do a basic camber kit on both the front and back. Most of it will depend on future plans too. I have the ones that bolt to the control arms at the strut towers for front and a $15 camber kit for the back. The front can be either the ones at the strut towers or the upper ball joints. I don't suggest the $15 camber kit because it may be cheap, it doesn't always work. I still have wear on the inside on my back tires. Your wheels and tires shouldn't have affected the wear on the inside.
its very similar to what you would pay for from ingalls. You pay for what you get. You can spend the 40 on it and see if it is any good. If so, then you are good to go, if not then you have to buy a more expensive kit. Suspension isnt something you wanna buy cheap.....atleast things such as balljoints, control arms and such.
It could help it. Wouldn't hurt to get a good alignment first. Make sure you tell them what is going on with it too.
