Resolved Identify this 6 bolt
danksauce
64
Aug 28, 2012
Hickory, North Carolina
Could anyone give me an idea about where this 6 bolt in my 2G FWD came from? Trying to make sure i am buying the correct parts for her. About all i know are that 6 bolts came out of 89-92 dsms and that mine has an N/T throttle body. Turbo is a 14b i assume which is the stock 6 bolt manual tranny turbo. It says TDO5H.
Bunch of pics included.
Solution
Ok i got it. Was an odd pic to take and its kinda marred up.
4A3CS44B8LE021142
Decoding VINs
1990 MITSU dsm 1g fwd.
Now about that intake mani, anyone reconize that? I havent seem one in all my searches.
Be careful rise compression to much ask for trubo
Its not a drastic change in compression. The 1g compression is lower then the 2g so if anything the 6bolt with the smaller cc hyundai head will put the compression closer to the stock 2g compression. The stock 2g ECU is already set for the higher compression that the 2g pistons have so he will be just fine.
I need to check and see what ecu is in this car. Ive been away with work and wont be back home until monday morning.
