I mixed the rod caps
jdm9221
125
5
Apr 10, 2017
Osceola, Indiana
so I have the rod caps on the right rods but I apperently flipped two of them around and I’m not sure which is right. Does the E go towards the front of the car or rear?
Take the cap off and look for the bearing tab indentation. Put the cap on the rod with cap and rod indentation on the same side. However the casting mark ends up after you do this is right.
Dont worry about the "E" not all caps even have them, the tabs on the rods where the bearing shells sit, both go on the same side so that they are facing each other, after that they both face the front of the block.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
