Hx40 pro Slow Spool
TxR6guy
136
Dec 18, 2006
Haltom, Texas
Mods:272 hks cams
Stock Head
Stock Intake manifold
Hx40 pro Bep housing
E85
2.0 liter
Stock 1g timing map
Having problem's getting this turbo to hit full boost, it's not hitting full boost till 6k and ive done a full boost leak test turbo has 1,000k miles on it and no exhaust restrictions..getting kind of stumped right now.
Any Ideas?
No exhaust restrictions...
No pre-turbo leaks
Both of those items i verified and not the issue :(
Ik u did a BLT but did you spray down your compressor cover and make sure your not loosing tons of boost there? Thats about all else I can think of that would cause that.... other than bad valves that arent sealing when they seat
There are several factors that can contribute to a slow spooling turbo. The BEP DSM bolt-on turbine housing should hit 20+ PSI by 5000 RPM with the HX40 Pro no problem. Here are a few things to check:
I know you said you did a boost leak test, but I would try it again with the engine in 4 different locations (exhaust valves open for each cylinder). This will check to make sure your exhaust valve stem seals are not leaking. Be sure to warm up the engine first.
Make sure the timing is set correctly and not off by 1 tooth (it is possible to be off by 1 cam gear tooth and not smash the piston with a valve).
Take the turbo air intake off and spin the turbo with your hand. Make sure it spins freely.
Make sure the waste gate flapper is fully sealing shut when the actuator arm is attached. You can also try and loosen the actuator mounting bolts and try to apply some pre load to the waste gate flapper and re-tighten the actuator mounting bolts.
This may sound stupid, but make sure the correct O2 housing gasket is used. There are several different flavors of these and they all look very similar to one another. There are O2 housing gaskets for the following Mitsubishi turbine housings:
6cm O2 housing gasket
7cm O2 housing gasket
7cm EVO III O2 housing gasket
I think there may be a 3rd 7cm O2 housing gasket, but not positive
8cm O2 housing gasket
Is there any kind of boost controller installed? If so make sure it is connected properly and is functioning as intended.
Has it been slow spooling since day 1 of the turbo install? If not, what was the last thing that was changed before this started happening.
On a side note, you should submit that turbo to the Guinness Book Of World Records, as 1,000k miles = 1,000,000 miles!!! ROFL Sorry had to poke fun at ya on that one :D
Definitely not the turbo.
7-blade 60mm HX40 in a .55 BEP housing reaches full street boost (25psi) at around 4200-4300rpms in 3rd gear on level ground in my buddy Stryker's 1G. The car does have a built low end with 8.5:1 compression pistons, a 2G head, Evo III intake manifold, and Kelford cams on stock cam gears....but those parts aren't going to make an 1800-rpm difference in spool.
This post is money! Do everything he suggested in that post. :thumb: :thumb:
Great suggestions on here, all of wich ive done :( why im stumped. As for the 1,000,000 LOL i was exhausted last nite darn dsm's.:p
Mods:272 hks cams
Stock Head
E85
2.0 liter
Stock 1g timing map
Any Ideas?
What gear are you doing the test in? Does your car have a catalytic converter?
Do a boost leak test with throttle open and intake valves closed. this will check for a leak at the intake manifold.
Have somebody two step the car, build boost, while u look from under the hood for leaks. Disconnect fans so they wont blow and confused you.
