1G How to remove factory 1G Sunroof glass
I took these a while back and intended to resize and post them since many people don't have the owners manual.
This is the factory stock sunroof.
Ignore the droopy headliner. I haven't gotten around to fixing it yet.
Pull the sunroof handle down to release the tension then push the red button forward and up and hold it. (I haven't released the latch yet in this picture)
With you other hand squeeze the two silver armed latches together (one is spring loaded) to clear the housing to get it to come out.
Since I need one hand for the camera you don't get to see that..
Latch is now free.
This is where you squeeze this part when taking it out or putting it back in the mount
Lift up the glass and it will come out.
A better view of the fitting up front where both the glass roof and the air deflector fit.
The sunroof and deflector tabs are curved to fix in and you have to rase or lower then as you put them in the fittings or then will bind.
You can just see the catch on the passenger side the holds the deflector down on the right hand lower side of the deflector. There is a matching hook on the drivers side.
The last picture shows both releases to remove it.
I should have washed the car before taking these but this was prompted by a members question.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
