How To: Electronic Boost Controller/Boost By Gear for less than $50
khomza
50
5
Jun 4, 2010
Fredericksburg, Virginia
I tried searching the forums for this and found no result so I figured out how to do it from friends that had done this and I'll write it up for all of you that were wondering. This writeup is for the way I did it. Increase boost in small increments of 5-10 percent, I am not responsible for any damages (i.e. your engine, turbo, etc.) from trying to jump ahead and over-boosting
If you have DSMLink V3 and would like to do boost by gear with an electronic boost controller for less than $50 here's how!
1. Buy this part 35A-AAA-DDBA-1BA Here's a link to it from Grainger http://www.grainger.com/Grainger/INGERSOLLRANDARO-Solenoid-Valve-6JJ52?Pid=search
Buy 2x 1/8" barb fittings such as http://www.grainger.com/Grainger/PARKER-Hose-Barb-3HCC2?Pid=search
2. When they come in, cut the wires to your stock boost actuator and wire them in to the new one, it doesnt matter which wire goes where. Solder the connections, if they come loose they will leave the wastegate open and the turbo will spool forever. Connect the barb fittings on the lower hole on the side where there are two holes and connect this line to your boost source i.e. intake manifold. Connect the second barb fitting to the side where there is only 1 fitting hole and connect this to your wastegate. Mount the solenoid.
3. Download and install DSMLink early access v3.20.254
4. Upgrade your ECU firmware- In ECMLink at the top, click "ECU" then click "create firmware request" and save it to your desktop or where ever.
5. Download the latest firmware upgrade by using the link near the bottom of the home page of ecmtuning.com. Click the link and upload your saved file and it will give you a link to download the new firmware.
6. Click ECU again atthe top of the ECMLink program and click "Upgrade firmware" and use the file you just downloaded.
7. Now that you have the latest software and firmware click "ECU config live" and then click "Boost (WGS)"
8. If you have a MAP sensor already set up go to step 9, if not or EVEN IF YOU DONT HAVE ONE got to ECU inputs at the bottom of ECU Config Live and on the "Manifold pressure" set up your MAP, if you don't have one click the dropdown and select MDP, on the next "Map sensor type" dropdown menu select "omni power 4 bar".
9. Go back to "Boost (wgs)" and click "enable boost control" and select the "disable error correction" checkbox if it is not selected.
10. To change the boost use the second table on this screen and you can change the settings by rpm and gear, fourth and fifth use the settings fron the third gear configs.
0=closed or no boost, 100% is wide open and gives no restriction to spooling. I wont give baseline settings because each turbo is different. so move up in 5-10 percent increments or so until you get your desired boost for that gear, the first 2 or three boxes CAN be 100% so it will spool quickly but see how your car reacts!
**When you are hitting peak boost it is normal for the boost gauge to flutter a little at the peak, its's just how the electronic wastegate actuator works**
ADJUST SLOWLY, Do not overboost! I am not responsible for your settings, engine, turbo, etc. It's tune then test.
If you have a better way of doing this feel free to make corrections or suggestions. If you have questions, first re-read the write-up.
FYI, this is the same part that comes in the AEM truboost kit except it's controlled by dsmlink and not the AEM boost gauge. AEM literally just puts their sticker over the actuator
The chart below was my base tune for my 16g turbo, I believe it was running somewhere between 18-22 psi (it was a while ago). Now I'm using this method on an externally wastegated hx35 with a 12 lb spring and it holds up to 25 psi (which is the highest I've tested). Adding a stronger spring will reduce the percentages in the table.
It might help, I've never had a map sensor and I've been using this method for months, it's been 100% accurate for me, with both internal and external wastegate turbos. I don't know what utilizing a map sensor would affect since I've never tuned someone elses car for this that had one. I don't assume it would be all that much different.
Well I tagged this post as helpful and I think it should be a sticky! This is a awesome feature of Ecmlink many users including me have'nt tried yet. Thanks for the write up!
I've been asked where to mount the solenoid, try to mount the solenoid near the original's location, I don't know how it would handle the heat if it were mounted near the turbo. The solenoid has a hole going through it in the middle so I just found a small, 1-1.5" long metric screw and bolted it near the location where the stock up-pipe bolted to (under the fuse box).
The MAP sensor is for error correction. You can set up the solenoid to have a base WGDC which is the way that you have described, and then use error correction based on the MAP feedback to reach a certain boost despite varying conditions, or other issues. If the MAP feedback says that the boost is too high or too low it lowers or raises the entire boost curve by a certain percentage which may or may not be user-defineable in dsmlink.
At least this is the way that it works with Evo ecus. I personally don't use error correction even though I have a MAP sensor but if I were setting something like this up for another person then I would make it active. I'm not sure also whether dsmlink allows this or not but with the Evo version you can choose to either have your error correction based on load or manifold pressure.
Awesome, thanks for the clarification. When I finally get my speed density hooked up I'll make sure to set up my boost settings with error correction to see if it works any better. First I need to drop my hx35 so I can put 17lb springs in my Tial wg because the guy I got mine from said it had a 12lb and it actually has a 6lb. That seems to make electronic boost control little less effective.
Tagged yours as "helpful" btw.
