Greddy Electronic Boost Controller Question
Deadmoans
83
Nov 14, 2003
Des Moines, Iowa
I believe my greddy electronic boost controller is not working.
I called greddy for some troubleshooting tips. Checked all the connections and made sure it was properly installed, checked the dip switches on the back of the controller. Everything checks out, except that my boost gauge says I'm still boosting 25psi and I have the controller set at minimum.
Now this controller was installed probably 5-6 years ago when my dad had the car.
I have not checked the boost gauge set up but it sure seems to be consistent in it's readings.
Does anyone have some ideas. My mods list is updated if you need that info.
Have you tried another boost gauge just to be sure it's not the gauge, and are you positive that the boost controller is plumbed properly? Also, very clean car! Is it still a 7-bolt?
Thanks for the compliments!!!
Yes, it is still a 7 bolt.
I did check all the connections. I have since found out that the filter on one of the vacuum lines to the controller has a filter on it - could be plugged I guess. Plus this is the "old school" Greddy Profec B.
Maybe I'll play with the boost settings and see if they go up.
Gotta tell ya, I'm thinking going back to a nice simple manual boost controller.
