Ebay Electronic boost controller + turbo timer BCU+
Ruski
Sep 8, 2004
Miami, Florida
Guys what do you think about this turbo timer + boost controller
BCU+
4TH GEN - BRAND NEW!
Brand new 4th generation design - more than just a standalone electronic boost controller. It does these functions:
TURBO TIMER
BOOST CONTROLLER
TWO PROGRAMMABLE OUTPUTS
It has these features:
PRESSURE DISPLAY IN PSI
PROGRAMMABLE TURBO TIMER (CAN BE USED WITH DUAL OR SINGLE IGNITION)
PARKING BRAKE TURBO TIMER OVER RIDE
2 PROGRAMMABLE CHANNELS THAT CAN CONTROL
POSITIVE OR NEGATIVE CONTROL
NITROUS SOLENOID
INTERCOOLER SPRAYER SOLENOID
DEDICATED HI AND LO BOOST SETTINGS
PROGRAMMABLE WARNING SETTINGS (BEEP AND DISPLAY FLASH)
PROGRAMMABLE HI & LO GAIN
START BOOST CONTROL FOR QUICKEST SPOOLING
PROGRAMMABLE LIMIT SETTING TO PREVENT OVERBOOST
PEAK BOOST RECORDING AND LAST BOOST HOLD DISPLAY
TURBO TIMER CAN BE USED MANUALLY OR AUTOMATICALLY - SELF SETTING BASED ON BOOST & DURATION
VOLT METER DISPLAY
SOUNDS CAN BE TURNED ON AND OFF
DISPLAY IN 6 SETTABLE COLORS TO MATCH YOUR OEM GAUGES.
PROGRAMMABLE BASELINE PRESSURE (FOR USE AT HIGH ELEVATIONS)
Works with single or twin turbos, and runs internal or external wastegates up to 25.5PSI. This has a high quality internal pressure sensor, and a high quality fast response boost control solenoid.
This boost controller builds in the features of several items at once (turbo timer, boost controlled solenoid outputs, etc). It's fully programmable. It can be top or bottom side mounted and includes the mounting bracket and hardware as well as all harnessing. A full manual is included with all wiring diagrams, programming instructions and plumbing instructions for the wastegate and pressure sourcing.
Here is the link.
eBay Motors: Electronic boost controller + turbo timer + nitrous (item 380003858261 end time Mar-13-08 21:00:00 PDT)
I've seen that for a while. Havn't seen any detailed reviews about it from a DSMer. It has very nice features. For those who are looking for EBC, but also want a turbo timer and other features, it SEEMS like a nice all in one solution. The price seems to be fair. Considering the price of EBCs, and turbo timers separately. This unit is nice because it has an aux input for something else like nitrous and ic spray.
It's a space saver too, not having to find places to mount the many electronics.
Of course it all comes down to how does it perform, and unfortunately no one has any personal experience.
Will you be the first?
Why do you say it is suicide? Well that's why I made this post , in order to know if some has tried this BCU+.
Also i think is a good idea to put a turbo timer and a boost controller in one box. It will save space and money.
Cus my original idea was going for hks turbo timer for $100 and a greedy profec B II for $300.
Search XS Power, and you'll see some very mixed results. I think that they were the company that was selling turbos with glued together compressor housings that fell apart after a few miles. Now, its very possible that they've improved their QC, but, like was said before, do you want to be the 1st to find out?
That boost controller has been sold for several years under other names. I have had that same unit in my 3000gt VR4 for almost 2 years now without a problem. The one I have was sold under the brand name PIT BCU+ and was ~$350 from Summit Racing. It uses the same exact boost solenoid as my AEM unit in my GVR4. Not the best looking boost controller but it does what it says it does without a problem.
i dont know, i mean if it fails, whats the worst that could happen?.... blown motor LOL, i would just get a MBC or a greddy one, i have a greddy Profec B Spec II
Guys thank you for all your help, i just ordered a GReddy PRofec-B Spec II Black
