How Do I Turn The Bleeder Valve With a Hose On It?
spadepro22
1,206
14
Mar 13, 2008
Seneca, South Carolina
I'm bleeding my clutch today and I a hose on the bleeder, but how I'm I going to loosen and tighten it with that hose on it? Yes I've researched, but haven't found anything telling me how to do is besides the method of how to do it.
Have a spare one you can cut in half to get more clearance? :p
You should be able to remove the hose to loosen/tighten as fluid should only flow out when depressing the clutch pedal. Or see if you can loosen/tighten enough by hand to do the job, and then snug it up after you're done.
Guess Im just going to do it without the hose. Thanks
What you can do is get a speed bleeder. Crack it open, put a hose on it, pump, and bleed away, then remove the hose, and tighten it back up. They have a check valve, and don't need to be tightened, and broke loose repeatedly to bleed.
